Isolated Ground Duplex Outlets
Started by rollo, April 10, 2014, 08:11:15 AM
   Recently changed out non isolated ground duplex to isolated ground. Was using 5362A duplex [ Pass & Seymor ].
     The difference was noticeable in less noise, more info and deeper and tighter bass.
    Removing the brass clip that connects the two outlets and using ten gauge wire instead brought an improvement as well. Tried a little trick that Furutech uses to reduce unwanted resonance. They use a set screw from a back plate to put pressure on the duplex from the back. I could not duplicate the Furutech however used a wood dowel attached to back of duplex that when the duplex is screwed down the dowel puts pressure on the duplex from the back.
      A happy camper here. Next step getting them cryo treated. I thought this was definitely over kill and possibly a non issue. DEAD WRONG.
     In direct comparison to a non treated duplex [ using a quad outlet dedicated line so one treated one not ]
      The result being more open and natural with more music and inflections of such.
     If your all set up and think you cannot improve with this think again.
    T
mdfoy
Charles,
That sounds interesting. I am having 2 lines put in the basement for the system. I  have a Porter Port that has that strap. Can you provide a picture of what you did?
Mike
  Not good at that sorry.
