LeAnna EV Custom Class A Preamp - Cherry Hardwood - <$1,000
Started by Response Audio, February 06, 2015, 11:03:48 AM
Response Audio
Custom built no-frills LeAnna EV linestage providing a beautiful presentation in a Cherry hardwood chassis at an affordable price. Uses the LeAnna 12AU7 low gain circuit. Solid state (non choke filtered) power supply. Built in aluminum sub chassis with 1/4" Cherry hardwood casing finish in gloss polyurethane.  Black aluminum control knobs. Chassis measures 10-1/2" W x 6-1/4" D x 3" H. Does NOT come equipped with power cord.
Inputs: 2x single ended
Outputs: 2x single ended
Gain: 16dB
Input impedance: 100K ohms
Output impedance 1k ohms
Frequency response: 17Hz->1mHz
Phase: Inverts
Tubes: 2x 12AU7
Asking Price: $850 $750 for AN members and visitors shipping included. 1 year warranty.
More to be found at our Custom Shop http://www.responseaudiony.com/customshop.htm
Response Audio NY
Custom Vacuum Tube Deaign
www.ResponseAudioNY.com
Response Audio
Response Audio NY
StereoNut
Response Audio
Thanks Nut!
I will take offers from AN viewers.
There are also a few more very unique custom pieces in the works. You can see whats happening at http://www.responseaudiony.com/customshop.htm
Response Audio NY
Response Audio
This is a custom LeAnna preamp using the balanced 12AU7 circuit that is equipped with Bluetooth capability and transformer coupled balanced outputs.
The chassis is constructed of 1/2" Baltic Birch Ply with 1/4" Hardwood for a 3/4" thick chassis. Sides and the removable top as well as the control knobs are Black Walnut with the front panel being a nice Cherry wood. Chassis size: 16-1/2" x 12" x 5"
This is a choke filtered, solid state power supply design with large, high capacitance filter banks and high current toroidal transformer.
Features: -- Bluetooth input (#4 input) -- 3 sets single ended inputs -- 2 sets single ended outputs (transformer coupled) -- XLR balanced outputs (transformer coupled) -- Clarity Cap ESA output capacitors -- Over 950uF of capacitance in the power supply -- 24 step attenuator - Cryogenically treated Silver plated copper wire in Teflon signal wire throughout.
Suggested Retail Price: $3,450
Selling Price: $2,450
Response Audio NY
  Looking real good there Bill. Just recommended to someone on AC. Good luck.
Response Audio
Here are some pictures of the custom Bluetooth LeAnna preamp in action.
$2,450 includes shipping and paypal for AN members and vistors seeing this thread.
Response Audio NY
Response Audio
Hi Charles. In April of this year I will have been married 21 years. Facebook?
Response Audio NY
Response Audio
#9
Here is a custom ordered single ended Musica Bella LeAnna VTPS. To save money to put into the circuit itself, the customer chose to go with a less expensive chassis. This chassis is constructed of 3/4" and 1/2" Baltic Birch Ply. Inside you will find our highly regarded choke input 'Vacuum Tube Power Supply" designed around the 5U4/274B tube rectifier. This piece also utilizes V-Cap OIMP output capacitors, highly regulated DC supply for the tube heaters and a GoldPoint step attenuator. Only thing left at this time is the front panel lettering.We can custom build a LeAnna preamp with whatever feature you want and leave out those you don't.
Response Audio NY
Response Audio
Details on both can be seen at http://www.responseaudiony.com/customshop.htm
Price lowered on this piece to $499
Price lowered on this one to $1,499
Response Audio NY
Response Audio
Response Audio NY
Response Audio
Response Audio NY
Response Audio
#13
We have had a few inquiries on this smaller preamp so we are making it available for $650 including Paypal and a flat $20 shipping. Your choice of Cherry, Black Walnut or "Ebony" Walnut.
The LeAnna is still available for only $1,295
Response Audio NY
Response Audio
We are going to do a small run of the Little LeAnna preamplifiers.
The perfect piece for someone looking for a no frills, great sounding tube preamp.
$650 + $20 shipping. Includes Paypal fees.
Details: http://www.responseaudiony.com/little-leanna.html
Response Audio NY
