Open baffle planars and servo subs
Started by HAL, March 12, 2016, 05:22:35 AM
HAL
Magically, the #4 woodscrews just arrived with no tracking data.
Second baffle completed and ready for when the FPS drivers arrive from PE, also no tracking info.
Next up measuring speaker #1.
HAL
First speaker is completed and ready for testing.  Will setup the measurement gear tomorrow to begin.
HAL
First CLIO Pocket measurement of the FPS array without the servo subs. With some simple shelving filters should be able to flatten out the HF response of the array.
FR not bad at all!  :thumb:
Amplitude scale is very zoomed in.
HP 4th order around 600Hz?
HAL
The hp is at 125Hz at this point, single pole.
Going to try a shelving filter and see what happens.
Just figured out the gating function in this version, and found the first bounce to remove.  Will see what happens.
jessearias
How do you measure the frequency response? With a mike or mikes?  What program are you using?
I always thought you needed an anechoic chamber to test speakers or drivers. But I like this do it at home method.
HAL
I use an Audiomatica CLIO Pocket system that comes with a calibrated Omni mic.  Parts Express sells them for $525.00.  I use it for a lot more than just speaker measurements.
If you want to get started, I would recommend reading about gated time speaker measurements, download Room EQ Wizard and get a Dayton Audio UMM-6 calibrated mic from Parts Express.  If the sound card or DAC on your PC is a good one it will work for in home frequency response measurements.
_Scotty_
Rich, does the Pocket CLIO give very different measurements than REW with a calibrated USB mic.
I've had good results with Dayton OmniMic. I found it much easier to use than REW.
HAL
Quote from: _Scotty_ on April 14, 2016, 10:28:53 AM
Scotty,
No, but I can make electrical measurements with CLIO pocket but not REW.
For speaker and room measurements REW is fine.
HAL
Setup my CLIO Standard 8.5 system to take measurements of the line array.  Packing up the Pocket CLIO to ship out for some measurements.
Have it warming up now and will see what happens.
HAL
Did the measurements and compared the line array with and without the beamformer.  The red trace is without the beamformer and the green is with the beamformer.  Getting around 5dB of gain at 100Hz.  This is now looking good.
Finished installing the FPS planar drivers in the left speaker and speaker cables ready to connect.
HAL
Just a bit more wiring and it will be time for listening.
HAL
HAL
All 12 amp channels and 12 FPS planars are working and making music.
Today will try some CLIO measurements to see how well I have the EQ setup to work with the servo subs.
