Musica Bella Audio Lusso -Twin Chassis, Balanced Tube Linestage - Extended Offer
Started by Response Audio, April 09, 2017, 04:14:32 PM
Response Audio
Extended pricing till end of April 2017
Regular selling price - $5,500 - Current selling price $4,800 (either power supply)
Retail - $7,995 SS power supply \ $8,500 VTPS power supply
The Musica Bella Lusso All-Out-Assault linestage is a true reference quality linestage that was brought forth to provide reference quality performance at factory direct pricing. All units are custom built to order. The Lusso is voiced to offer solid state speed with vacuum tube soul. Bass is deep, tight, fast and authoritative with just the right balance of body and warmth from the 12AU7 tube stage. A clean, crisp yet lively midrange and upper end with an uncanny sense of air and detail brings emotion back to your listening experience. The use of quality components throughout allows for a great sense of detail, transparency and resolution while maintaining the musical purity true music lovers lust for.
The gain stage circuit is based on a single 12AU7 tube per channel and is designed with a constant current source topology. Signal path components include high precision Carbon Film resistors, DynamiCap output capacitors feeding balanced output transformers that provide transformer coupling for both balanced and single ended outputs and high quality cryogenically treated silver plated copper signal wiring with Teflon dielectric. Balanced input transformers provide transformer coupling for both XLR balanced and RCA single ended inputs. A GoldPoint step attenuator is optional
http://www.responseaudiony.com/lusso.html
VTPS (Vacuum Tube Power Supply)
Choke Input Design using the 5U4 or 274B
http://www.responseaudiony.com/vtps---outboard-tube-power-supply.html
Response Audio NY
Custom Vacuum Tube Deaign
www.ResponseAudioNY.com
