Cartridge Survey
Started by rollo, February 15, 2018, 08:43:13 AM
jimbones
Benz Micro Glider MC Medium output
JMW Memorial Classic 2
Modwright LS100 Tube pre with Mullard NOS 12AU7/12AX7
Quote from: jimbones on March 20, 2018, 05:02:02 AM
OOh la la time for a meeting Jim.
jimbones
Quote from: rollo on March 20, 2018, 10:29:08 AM
Just had one :) There will be more. We played vinyl almost exclusively. It was clear that vinyl was superior.
Bill O'Connell
Quote from: Nick B on February 23, 2018, 02:30:16 PM
Quote from: Bill O'Connell on February 23, 2018, 08:44:30 AM
Well Tempered Reference turntable & arm
Audio- technica Art9 cartridge
Tom Tutay/ Transition Audio Design 12SN7 based all tube phone preamp with separate tube power supply
or Eastern Electric MiniMax phono
Hi-Fidelity Ultra Reference IC's
Hey Bill,
To deviate just a bit from the thread, how do you like the Hi-Fidelity Ultra Ref cables? I dont know of anyone who has them.
If I had to do over again I would not spend that type of money on IC's & speaker cables again.
Don't get me wrong, they sound great but less expensive options I would be swayed to check out.
Bill O'Connell,
847-255-1150
try1256
I have the Sound Smith Aida. It was rebuilt by Peter Lederman in January.  It is attached to an SME M2-9 tone arm on a Thorens TD-160 rest-mod.  Right now I am using the Van Den Hull Cable that came with the tone arm but I have an Audio Sensibility Impact SE on the way. I have a Morrow PH-3 phono cable that I was using but the capacitance was too high for the Aida. My phono stage is a BAT VK-P5 which was upgraded at the factory with the 6 pak plus option.  I have NOS Phillips 7DJ8's on the input side, Russian 6C45's on the output side and Melz 6SN7's for current source.
Before I acquired the Aida, I was using an AT OC9 ML II. It is also a very nice cart. I have it mounted on my Yamaha PX-3 Linear tracker now.
"It is always easier to get forgiven than it is to get permission"
#20
Quote from: rollo on February 15, 2018, 08:43:13 AM
  Which one are you using ?
  What TT and arm ?
  What phono stage ?
  What cabling of such ?
  What plinth or support of TT ?
Using a Kuzma Stobi with Stogi S 12" arm, Crystal Cable phono cable [ silver] to Audio Hungary APR 204 preamp with MM phono. Or Loesch and Weisner phono.
I am using an Accutex 320STR moving iron cartridge.
SME Series lll with modified headshell.
My own test phono stage.
my own 1/2 meter "V" interconnects (SAS Audio Labs)
Mimir Modified DAC
SAS 20 W Ref Triode 40 W UL
S Clark
Main rig-  Vyger Timor Arm #1 Jelco 370 arm, Ortofon Quintet Blue,  Jelco cable, Dodd phono pre Arm #2 Dynavector 20x2L  on Pioneer P3 arm and Audio Sensibility Impact cable to Jolida JD9 phono pre
Small room rig-  JVC QL-F6 with lots of clay, Dynavector 10x4, Graham Slee Gold, captured cable.  And a Technics SP10 II  w/ Syntec 220 arn with Denon 102 mono cart to Vista phono pre.  I've had the cable so long I can't remember the maker.
Coming attractions... a Victor TT81  to be recapped and a Jelco 750E with a Sumiko Blackbird.  Just have to build the arm pod and recap the table- maybe before XMas.
I know, I've got too many turntables.
jbtrio
VPI Classic 3 turntable, 3d printed tonearm, Lyra Kleos SL cartridge, sitting on a 2" maple platform with Herbies tenderfeet under it. K&K Audio Premium Maxxed-out phonostage all connected with High Fidelity Ultimate IC's and TWL power cords.
VPI classic3,3d arm, Lyra Kleos SL,K&K maxxed-out phonostage,Quadratic MC-1 SUT,Mola Mola Tambaqui Dac, Jay's Audio CDT-2 Mk.3transport,Supratek Sauvignon preamp,Frankenstein 300b mk.2 amps,FW SIT-3 amp, Purepower 1500+,Horning Eufrodite Ellipse speakers
Since 2011;
VPI Super ScoutMaster with the Acrylic upgrade platter and ring clamp.
JMW 9 tonearm - Signature version.
Dynavector 20x2-L
Stainless Steel clamp
SDS
Optional HRX footers on Ginko Cloud base on 5 HVAC vibration suppressors on a Cambre rack.
HRX motor.
E.A.R. 834 Signature Phono Preamp with 3 smoothplate NOS Telefunkens.
Yesterday as I removed the Ginko dustcover, a big piece, I whacked the base of the tonearm assembly and threw off the geometry, the cartridge where the stylus enters appears to be touching the vinyl
If I'm going to take down the tt to adjust everything, I feel like this may be the time to swap out the cartridge, but for what? When I bought the Dynavector I also grabbed a used Shelter 501 off Audiogon, I really preferred the Shelter for the upper music range, but my hearing in the highs was succumbing to age, I'm 61, I went with the DV. And now with the Vandersteen 3A Signature in house, I may need to balance their natural warmth with a 'sweeter in the highs' cartridge.
And maybe I should have a pro do the install, I never really feel like I had the Dynavector 100% correct.
Thoughts?
Gene
HAL
Oracle Delphi MKI TT moded with MKV suspension.
SME 3009 Series III titanium arm.
SME cable.
Shure Ultra 500 cartridge and original stylus.
DSA Phono One phone stage or Pass Labs Aleph Ono.
toobluvr
#25
Quote from: mdconnelly on March 18, 2018, 01:22:55 PM
Totally missed this thread last month...
Kuzma Stabi S with Stogi S arm
Kuzma stock cable and motor
ZYX Fuji high-output MC cartridge
all into my Devialet 440 Expert Pro phono section input
I love this Kuzma turntable.   Definitely owned this longer than any other piece of gear - maybe 20 years now?   Sounds wonderful but, in truth, I find myself spinning vinyl less and less these days.  Maybe I'm just getting lazy in my old age or maybe streaming has just gotten that much better.  Likely both.
Years ago I owned the Kuzma Stabi / Stogi "s" setup (the pipebomb!).
Loved it.....sold it....would buy it again if I saw a good deal.  Like Rollo sez, hugely underappreciated kit that suffers from  poor marketing.
On another table, I also used the Kuzma Stogi Reference arm.  Tremendous arm, probably my fave of all I've owned:
Rega 300
Graham 1.5 t/c
SME V
Linn Ittok
Moerch up-9
Jelco 750E
Hadcock 242
OL Encounter mk3C
OL Silver mk3A
The OL arms are really excellent in their own right!
TT2: OL Aurora/OL Silver Mk3A
Triode Pete
Well Tempered Reference TT with carbon fiber WT Reference Arm...
Clearaudio Maestro II MM cartridge...
Specially designed shielded TWL phono cable to MATCH the cartridge and phono input. In the case of my Clearaudio cartridge, I have 220pf of total loading capacitance. My tonearm wiring is 25pf along with my TWL interconnect is 95pf together with 100pf of the phono input, these capacitances form a parallel circuit with a total sum of 220pf that basically guarantees an exact match for my cartridge (and most moving magnet cartridges). This balances the cartridges inductance which is usually in the region of 500mH and the 47K input resistance controls the overall resonant Q.
Extremely important since if the overall capacitance is too low, you would have peaks at a higher frequency, causing upper midrange losses (The midrange is where you live!)... Too high capacitance, you would have peaks in the upper midrange, causing high frequency losses!
I remember SME having a high capacitance phono interconnect and those using a MM cartridge were caught off-guard not knowing the cable was designed for MC!!!
So the lesson here is to have a properly designed phono interconnect to match your cartridge!! Don't forget about that!
My $0.02 for today,
Pete
Quote from: jimbones on March 27, 2018, 02:59:14 PM
   I would suggest your digital is severely lacking then. :-P :D :rofl: :rofl: :rofl: :rofl:
  Pete, so true. Most do not have the optimum capt. loading. When they finally get it set properly OMG. Wiring counts.
#29
Here is a link for anyone who may wish to tinker and explore what is possible, or simply check and calculate
cartridge loading.
http://www.hagtech.com/loading.html
Mimir Modified DAC
