Cartridge Survey
Started by rollo, February 15, 2018, 08:43:13 AM
toobluvr
TT2: OL Aurora/OL Silver Mk3A
#31
Quote from: toobluvr on February 04, 2019, 10:05:47 AM
Another good one that's loaded with useful info:
http://www.rothwellaudioproducts.co.uk/html/mc_step-up_transformers_explai.html
Very nice article Toobluvr. Thanks for posting it. I do have a couple of quick comments that I
think will help some.
1. Although photo 1D appears flatter, it actually has almost as much slope as photo 1A. I had
the same misconception when I performed some testing years ago. When I expanded the
vertical of 1D to match 1A on my Tektronix scope, the two slopes were close. Just my observation.
2. For those who wish to minimize the ringing, and don't know what capacitance to use/order, the value
will be in the low pf (uuf) range. This means probably a polystryene type. Just throwing out a value,
maybe a 100pf. Could be much more or less depending upon the ringing frequency.
Mimir Modified DAC
SAS 20 W Ref Triode 40 W UL
Brap
Ortofon Quintet Bronze
Rega 3
Rega wall mount
Vincent PHO
Fritz Carrera 7 Be
VTA ST-70
Parasound Halo P5
Oppo 105
Rega P3
Cambridge CXN streamer
Teac 3340S
Anticables 3.1
