PIAUDIO BETABUSS
Started by rollo, March 27, 2018, 11:26:54 AM
djdube525
Quote from: doug s. on April 25, 2018, 03:59:33 PM
i start a new job and my 1st project is to oversee the installation of a 5mw solar grid for nist.
Out of curiosity... NIST in Boulder, CO or MD?
Quote from: TrueAudio on April 25, 2018, 10:28:50 AM
Start by educating yourself:
Thanks for the info TrueAudio! My wife's head while sleeping is 4 feet from the smart meter.  :shock:
dBe
Quote from: doug s. on April 25, 2018, 06:58:07 PM
Quote from: djdube525 on April 25, 2018, 06:40:24 PM
gaithersburg, md; which is 25-32 miles from my house (depending on the route); which means about a 45 minute commute; the shortest i have had in years!  i will also be involved w/a smaller set-up in quantico, va, but i won't have to go there more than 1-2 times/month.
doug s.
Great to see you got a good gig, Doug  :thumb:
Quote from: richidoo on April 25, 2018, 06:48:57 PM
  Richidoo not good move the bed or meter. I repeat not good. I know you know so move that bed. Get a Guass meter and measure that field. You will be shocked as to the amount.
Quote from: rollo on April 26, 2018, 12:45:21 PM
Thanks Charlie, yes I'm working on fixing it. Gonna get a meter to measure RF, then try faraday cage over the meter. Only the glass fishbowl part is not solid steel box, so that's where the 900MHz signal gets out. It broadcasts a very high power signal.
dBe
Quote from: richidoo on April 26, 2018, 04:05:08 PM
You can download a gauss meter that is pretty darned good from:
Android - https://play.google.com/store/apps/details?id=com.keuwl.gaussmeter&hl=en_US
iPhone - https://itunes.apple.com/us/app/gaussmeter-teslameter/id930488579?mt=8
You will be amazed at the EMI/RFI hell that we live in!   :shock:
Thanks Dave. As I understand it you need a RF meter to check the smart meter emissions and they cost more than ghostbuster magnetic and electric field meters on amazon. But I found a rental  :lol:  Sorry for the hijack
dBe
Quote from: richidoo on April 26, 2018, 08:37:22 PM
Not a hijack by any means, but what I would call an adjunct.   :)
dBe
Results so far:
Mixed.  I'm a bit frustrated concerning some of the results that I'm getting and I'm not sure if it is due to a design with linited application or not being able to control the installation.
I would encourage those of you with tem to disregard my installation instructions and try the Depot in any receptacle that you deem fit.  It should find great application on the circuit with computers and thos type of power supplies or near your TV, etc.
Move them around and let us all know.
OK.  This doesn't count.  Obvious spousal bias.
My wife says that with it plugged into the same receptacle as our Samsung 60" LED TV it has never looked better.  Blacker blacks; better edge definition (she said "everything just looks 'sharper') and more vibrant colors.
My 70 year old eyes have to agree.  I need to build another one for us to calm the appliances back down.
Live and learn.
YMMV... it's subjective as always.  :)
TrueAudio
Watch this video (Alan Maher on noise):  https://www.youtube.com/watch?v=hRqPEOoO69U
Quote from: TrueAudio on May 07, 2018, 06:21:19 PM
Wow...great video. Had no idea the extent of noise pollution from so many devides, and how about that $2,800 power cord.
I didn't catch what device he was using to measure/hear the noise. Also, didn't follow what he was saying about smart meters and transmission of microwaves.
  Move it around for best results. Actually for me using on same circuit as sub panel for system now. Previously on branch circuit, go figure. BUY ONE.
mauidan
As I told Dave, I couldn't measure any difference with my Entech Noise Sniffer when the BETABUSS was plugged in to a circuit across or below the breaker my system is on.
Based rollo's post, I plugged it in the same circuit my system is on.
I adjusted the Entech Noise Sniffer's Sensitivity until the display showed 100.
Turning the BETABUSS on, dropped the reading on the display to under 5.
Quote from: mauidan on May 20, 2018, 10:01:30 PM
Thanks for checking in, Dan.
My results, only different.  On my opposite branch, I heard the 'fridge get noticeably quieter.  I was so curious I broke out my venerable (read as old, but still functioning... Like me) Audio ToolBox as well as my B&K 2250 sound level meter.  Both of them caught the running noise level at about -2dB relative to SPL without the Depot in place.  Doesn't sound like much, but that amounts to a 37% reduction in SPL.
Gayle liked the Depot so much on the same receptacle with the TV, Direct TV receiver and DVD player that I'm having to build one for there (her).
Some systems or old ears will not hear the electrical noise reduction as a stark change.  Putting it on the same branch in a different location makes a distinct difference.  Even Dan's system that is treated with an Uber showed a sizable difference.  It started out VERY quiet with the Uber and got quieter with the Depot.  I'll take that  :thumb:
