PIAUDIO BETABUSS
Started by rollo, March 27, 2018, 11:26:54 AM
Quite a difference in measurements in Dan's system. Somewhere in my garage I have an emf meter and I'll be curious what those readings will show.
Dave, as the results can vary per user and placement, can you conjecture what factors might be involved? Also, if it's not proprietary, can you comment if your methodology is similar to the old Audio Prism Quiet Line modules? They worked well If I recall correctly, but I just got tired of having so many of them plugged into my outlets.
TrueAudio
Quote from: Nick B on May 07, 2018, 09:59:19 PM
Also, didn't follow what he was saying about smart meters and transmission of microwaves.
Check out this other video (I recommend everyone watch this):
http://www.dailymotion.com/video/xqt5lq
"The measuring of the Frequencies and RF's are shown here and the dangers of these damnable meters ongoing in AZ."
Quote from: TrueAudio on May 31, 2018, 02:02:23 PM
+1  :shock:
Quote from: Nick B on May 22, 2018, 08:03:09 AM
Differential line noise that exists on AC lines is a type that is easily suppressed. It is a tiny component of AC noise and can be dealt with cheaply.  It prevails when there is a high-ish DC component on the power lines.  Several orders of magnitude higher is common mode noise that is the real culprit.  Audio Prism and PS Audio produced devices to deal with this noise along with others.  Their theory of operation was to strip off the HF noise components with simple LC networks and then turn that noise into heat through the use of a diode.  This is an over simplification, but that is essentially their function.  Problem is that most of this filtration is happening > 100KHz.  This helps tweeters live, but is inadequate for broadband noise suppression.  My products share nothing in common with those devices other than they contain wire, resistors and capacitors.
Very interesting and concerning as well. We are bombarded with so many external stimuli from so many sources like chemicals, food additives, microwaves, emf,  etc etc that its a wonder that our immune ststems can tolerate them. Then there are those folks who are affected and it must be a needle in a haystack to figure out what it might be.
TrueAudio
#80
Quote from: P.I. on March 27, 2018, 01:10:25 PM
Quote from: HAL on March 27, 2018, 12:05:53 PM
Ok, so have a DigiBUSS and UberBUSS for the front end and BlunderBUSS and MiniBUSS for the amps in the system now with TWL's power cables.
What would the BetaBUSS do in that case?
Rich, you use it on the opposite branch circuit (phase, other side of the panel... whatever) to address the noise on that branch.  It is about further noise reduction on the Neutral as well as RFI on that branch.  The effects are not that subtle since the thigh bone is connected to the hip bone that stabilizes both legs.  Audio humor there.   8)
Again, more useable power under the curve on the opposite branch can't hurt, either.
Hi Dave, got my unit, I cannot thank you enough.  Will be evaluating it more when I have time, initial impressions, definitely many improvements.  That being said, I bolded your last sentence because it's quite important.  More usable power is exactly that--with all of the noise riding on the line, those are *non power frequencies*, and they do not just magically disappear when seen by anything that uses AC.  It causes thermal heating effects in motors, hysteresis losses, multiple things that cause inefficiency and also reduce longevity of electronics.  Lower frequencies from what I understand, around 300Hz, can actually cause counter-veiling magnetic "friction" in motors.  I was using a Bill Seneca designed (from the 1980's) Promethean Power-Flo as a parallel filter sharing the outlet that I have the Topaz Xformer plugged into, and your unit easily bests that even just going my measurements alone--your unit having better than double the noise reduction just being plugged into the same receptacle.  I notice similar effects as the digibuss in terms of seeming elimination of the digitalness, brittle, hardness of even streamed video/audio on my 4K player, and out-of nowhere fine clean detail and "the ability to see 'into' the picture" that simply was non-existent before plugging in the Buss Depot.  Legendary product in a world of "my technology is better than yours" - no advertising required.  I'll evaluate over this more in a few weeks.  Thanks again.
dflee
Dave is a force to be reckoned with.
Don
