Internal photos of 90's era Tice Power Block IIIA
Started by TrueAudio, June 18, 2018, 10:39:15 AM
TrueAudio
Saw this on Ebay.  Always wanted one of these old school power conditioners back in the day.  First time I've ever seen someone take pics like this which would have required removing the rivets from around the chassis.  Obviously, things have come a long way since this time.
Quote from: TrueAudio on June 18, 2018, 10:39:15 AM
I do remember the this Tice product quite well. Like cables and tweaks, this unit was a bit controversial iirc and a bit pricey. Don't know anyone who ever owned one.
I remember when someone knowledgeable looked inside the Hydra power conditioner about 10-15 years ago. They always advertised that it had something like 10 discrete components. What they translated to was something like this list:
case
cover
outlets to the components
incoming power supply outlet
incoming power cable
internal wire
X or Y rated capacitor across the line
Varistors across the line
circuit breaker
rubber feet
So basically the only thing inside that was truly "conditioning" the power was the Cap across the line and the varistor was there for surge suppression. Along came Jon Risch who DIY'ed his own version of this and specified good quality parts. So for about $100-200 on the outside you could make your own version of the $5000 Hydra.
I look at most of the old tech advertised for "clean power"
The chassi internals on the Tice device is filled with circuit boards with little more than one or two passive of incredibly modest values or a bunch of connectors that make it look deceptively busy (complex - like it all does something) and yet be woefully wanting in what needs to be done to incoming AC to truly address the major issues resident in transmitted AC.
I couldn't sleep at night if I put something out like that or the old Hydra.
Sheesh!!!   [-X
Quote from: P.I. on June 18, 2018, 09:59:59 PM
Sheesh!!!   [-X
We are very happy you do not do that.
