Do I need a poweramp?
Started by Ita0101, August 04, 2018, 02:29:56 PM
Ita0101
Hi,
I'm about to start build soon Jeff Bagby Adelphos speakers and I want to upgrade my amplification after it.
This is my system now:
Elipson Studio Pro bookshelf speakers
Denon AVR-X2400H
OLED TV
PC (Tidal)
SVS SB2000
Acoustic panels
I had Yamaha AS-501 before the Denon and I really like it for its price. The Denon is harsh with my speakers and less detailed compare to the AS-501.
If I understand correctly, I need a power amp to keep the Denon for HT uses?
Any recommendation for price range and brands I could buy internationally would be appreciated.
The next upgrade will be the source.
Itamar.
:thumb:
  I take it the Denon has an option to use as a preamp only [ 2ch] with an outboard amp. First question SS or tubed ? Second, budget ?
If possible consider an integrated amp for stereo and just use Denon for HT. You will get a much better preamp section for [2] ch. and amp in one enclosure.
  I like Audio Hungary products.
mresseguie
Hi, Itamar.
Rollo (Charles) is right to ask about your budget. We could offer 25 suggestions, but if they're all too expensive, it would be a wasted effort.
That said, I have found with my Adelphos:
1. My Nuprime IDA-8 ($995 USD) does a decent job of powering them. The IDA-8 is 100W/ch, has a DAC and preamp all in one compact unit. It's a keeper for my office system. However, my speakers do not shine with this amp. They sound okay though.
2. Folsom's Little Chip amp (forget how many watts...25/ch??). My Apelphos sound almost tube-like when they're powered by this amp. You buy it from Folsom (Jeremy) as a kit. It's very inexpensive. You'll still need to buy a DAC/preamp. It's very impressive for such a small amp.
3. I also own a Nuprime ST-10 amp ($1600??) (150w/ch). This is a very nice sounding amp the allows my Adelphos to shine. You'll need a separate DAC/preamp.
4. I do not own this, but a Nuprime IDA-16 has 200w/ch and a better DAC/preamp than the IDA-8 ($2000??)
5. My Don Sachs Kootenay120 KT88 tube amplifier makes my Adelphos sing in six languages and seduce the angriest neighbor. It is my 'amp to die for' ($3400). Hell, all of my speakers sound amazing powered by this amplifier. I still must pinch myself to make sure I'm not dreaming.
6. IceEdge 1200as2 amplifier (price varies, but approximately $1800 USD). Class D amp that sounds a lot like my tube amp. Up to 600w/ch! It's the wave of the future, I think. I believe there is an IceEdge 1200as2 amplifier dealer in Italy. [I'll ask a friend who knows for sure.]
Except for the IDA-16, I own all of the above mentioned amplifiers. My very first amp was a $600 Denon AVR that sounded like garbage. It didn't matter which speakers were powered by the AVR, they all sounded horrible. It was a $600 lesson on what not to do.
Good luck with your search, and have fun along the way. This is a great hobby.
Michael
Don Sachs Model 2 preamp
Hapa loom
  Being in the EU check out Audio Hungary Qualiton line.  The APX 200 [100W/ch] amplifier and APR 204 preamp. Lector in Italy makes some fine gear as well.
  For Class "D" IMHO hybrid is the answer . Meaning a tube input and class "D" output. The Arion HS500 using a 6H30 input tube and in house designed class"D" module is one to hear.
Ita0101
Michael, Charles and Nick - Thanks for your answers.
I had really busy time and I just now I have the time to finish the Adelphos and thinking about amps.
I understand that integrated amp is the way to go, but if I will purchase one additionally to the Denon, I will get lazy to hook the Denon every time I watch Netflix or movies in the weekend.
I might sell the Denon, its really nice on movies but I don't have much time to watch movies since I'm about to start learning (college) soon.
My budget now is around 500$, I think I will save more 500$ and try to sell the Denon before attempting to purchase something.
Thanks!
Quote from: Ita0101 on November 07, 2018, 01:14:49 PM
Thanks!
Thanks for the update 👍
Ita0101
I might keep the Denon and try to find an intergrated amp with ht by-pass.
Can some one explain me how it works?
Can I use it without any disadvantage?
Does amp like Rega Elicit / Naim 5si can work well with the Adelphos?
They have good retails here in Israel.
I found Lector ZAX 60 used in 1000$ (sounds expensive for it value?)
djdube525
Is DIY an option? Are you by chance handy with a soldering iron?
If not, and you are in the US, I'd suggest checking out https://www.accessories4less.com/ for refurbished items... some that come close to that budget that may be worth investigating (smidge over your budget)
Marantz 7025 (2x140W) @ $600
Yamaha S801 (2x100W) @ $600 (sounds like you liked the S501, a couple steps up the Yamaha line - gets solid reviews - comes w/a DAC if you need one)
Ita0101
I'm out of US and used Yamaha are bit expensive where I live (Israel).
DIY can be an option - Do you have a kit suggestion.
I like Yamaha sounds compares to Denon..
For DIY Audio Note kits are just awesome. The Lector is a VG piece. Have owned their products. $500 is a stretch for a quality Amp.
