Record Brushes
Started by Jack in Wilmington, August 24, 2018, 06:30:10 PM
Jack in Wilmington
I got the standard Goat's Hair Brush with my new record cleaning machine and a friend said to switch to a MoFi brush instead. I have a Record Doctor brush that looks identical to the MoFi brush, are they the same thing made by two different manufacturers?
Speakers........Dynaudio Contour 1.8 Mk II
Amp...............Pass Labs X150.5
PreAmp..........Cary SLP-03
Sources..........Music Hall MMF 9.3 Walnut w/  Goldring
Eroica LX MC Cartridge
Rotel RCD-1072
Okki Nokki.......Record Cleaning Machine
DAC...........
Folsom
I have a mofi if I want to spray something between cleanings with vacuum rcm. But I prefer this unless it is something not dry that got on the record. These in combination with antistatic are my preferance.
Triode Pete
jimbones
looks like a womans make-up brush!  :rofl: I'll borrow one from my daughter lol
   Consider as well Mapleshades brush. Grounded, Extremely affective and fairly priced.  Jim I used a expensive make up brush until I discoveerd it was creating static elec. Not good.
Number 1,  I think Jack is talking more about an applicator brush to be used during the wet cleaning with and RCM as opposed to a brush to simply sweep of surface dust in between cleanings.
Number 2, I know that the brush that Pete posted a picture of has a metal piece that says touch here for discharge, but keep in mind that touching that spot will do nothing unless you yourself have a good solid connection to ground. if you are standing there in a pair of rubber bottom sneakers and are not touching anything other than the brush there is no path to ground and no static drain off will occur.  The Mapleshade brush on the other hand had a wired connection to ground to insure that the static will have a place to go regardless of how the brush is held. This by the way is not a new idea. I have a 30 year old  brush put out by Oracle ttat has the same kind of ground wire.
