Line Polarity
Started by rollo, October 20, 2007, 07:11:35 AM
Are your components connected with the correct polarity to the power source? To find out get a multimeter and measure the ground potential. Simply set the meter to AC voltage and attach the black probe to ground and the red to the outter part of an RCA and read the meter. It should read 0 if in the proper polarity. Install a cheater plug and reverse the plug. Remeasure and go with the lowest reading if 0 is not possible. The component should not be connected to others when doing this. Your gonna be surprised when all is done.
rollo please clarify the procedure for dumdumhead over here - OK, you measure AC voltage between the ground pin of the AC power cord and the signal ground from an input/output jack? With wires connected or without? Plugged into wall or not?
I have some wicked hum on radio that I am killing with transformer, but it would be cool to track it down. I tried measuring it with DC but it always read 0. Never tried measuring AC even though it was 60Hz, shoulda thought of that...
Thanks!!!
Richadoo,
              Yes you plug in component and turn it on. ICs and speaker cables should be disconnected [ a good time to clean connecters ]. One probe [ black ] goes to earth ground the other [ red ] to the outter part of RCA of the component. Read meter. Then reverse plug [ use cheater ] and remeasure. The lowest reading is correct. Do this with each component.  Have fun. Its tedious but worth the effort.
OK, that sounds easy enough. Do I just pull the plug out of the wall slightly to gain access to ground pin?
I assume I can test the component using any recepticle, or must it be testing using the outlet in which I will plug it for regular use? That one is difficult to access with a probe. I have an outlet polarity test device and have confirmed correct polarity of every outlet in the house.
Richadoo,
              The screw of the wall plate is grounded. No need to use ground pin hole in outlet. Attach meter probe to screw. I use a wire connecter with an eyelet. I remove screw to wall plate and install connecter to screw and screw in. Are we clear.
Yes, that is smart. Then the ground can be extended to comfortable workspace.
Thanks rollo, this will fun to try.
