Last Musica Bella Spirit Tube linestage w/ MM phono
Started by Response Audio, March 12, 2019, 07:31:42 AM
Response Audio
Started assembling the last Spirit linestage.
Class A line stage circuit using 12AU7s.
RIAA  phono stage using one 12AX7 and one 12AU7.
Choke filtered solid state power supply.
Each tube stage, line and phono, utilizes its own regulated DC supply for tube filaments.
Clarify Cap Acrylic encapsulated output capacitors in the line stage.
SoniCap phono stage capacitors with Elba Cerafine bypass capacitors on tube cathodes.
Relay based input selector.
3 single ended I put plus one MM phono Input
2 single ended outputs
Alps Blue volume control.
2 year parts and labor warranty
Contact me for details or questions. Response34@aol.com
Response Audio NY
Custom Vacuum Tube Deaign
www.ResponseAudioNY.com
Response Audio
This last Spirit is now under construction. Please contact if interested.
Response Audio NY
Response Audio
Response Audio NY
