Here is what $700.00USD will buy from Italy...
Started by P.I., March 17, 2019, 11:43:18 AM
Recently I had a long time customer of mine send a HIDiamond P3 power cable to me for repair.  Somehow movers BROKE the end off of an IEC plug!  Gorillas?  Upon inspection I determined (with a file and some effort) the cheap IEC was silver plated brass.  Yep - bright brass.
Anyway, when I disassembled the cable I was frankly stunned at what I found.  It is made from 4 conductor + shield mass produced mains cable.  Efforts were made to sand off the markings on the cable to hide its' identity.  The individually insulated conductors are sheathed with PVC while the overall jacket appears to be the same.  What was astonishing to me was the "workmanship" at the termination.  I have attached a photo of the termination methods for your inspection and comments.
Pete.  You do tremendous work and your value/dollar is outstanding.  TWL rocks!!!
malloy
This reminds me of the cat and the power cord:
Quote from: malloy on March 17, 2019, 04:49:43 PM
What craftsmanship in disassembling it 🐈
Folsom
So, what do you expect to find?
The materials that make up the outside are not always cheap. Labor. Etc. I know nothing about the actual wire in either case. I guess you expect to see thicker wire?
S Clark
I agree with Dave's initial assessment- TWL rock.  I've got a small sampling of power cords other than stock stuff, and the TWL and Wywires are noticeabley the best of the group.  Pete knows what he's doing.
#5
Quote from: Folsom on March 17, 2019, 05:52:45 PM
Uh, no.  I have come to have no expectations many years ago.  I rebuilt a pair of $8000.00 speaker cables for a customer that wanted 2' removed to better fit in his new room.  They looked great and had very nice connectors.  Advertised as being made from special alloys, silver and gold.  They were enclosed in some clear PVC tubing that had the same markings as the tubing available in big box hardware stores.  The conductors were stranded red THHN 12ga wire.  There were 3 runs in the + leg and 2 runs in the negative leg. There was one run of 24ga silver wire (sterling, fine... I don't know) in Teflon tube in the + leg and one run of solid 18ga PVC insulated Carol wire in the return (-).  Solder terminations were hard as hell silver colored that accounted for "alloy".  At that time it was probably Sta-Brite (4% silver, 96% tin).  The spades were gold plated copper.  Ergo:  the letter of the ads was met, so no one could call foul.  They did sound very good.  So what?  $8K for less than $50.00 worth of materials?!?!
Again:  Uh. No!
What was disconcerting to me on the HIDiamond cable was the slimy electrical tape and solder joints that looked like they were done by a 12 year old.  The styrene plastic connector shells was pretty iffy, too.  It has a distinctive smell when heated.  Good old styrene monomer.
You and I both understand that our customers deserve more because we don't expect to get rich doing what we do.
Personally, I do this because I love it.  That is why I am finding it very hard to say "no" to current orders and actually retire...  :roll:
Folsom
None of it surpises me.
However I find it funny to hate on the cat shredded cord for the connectors. Those are my favorite connectors out of all connectors ever. The IEC I might consider going different on but I dunno... so far IMO you can't do better. I don't like exotic plating. And I prefer compression. Also I prefer connectors with the most straight forward shapes. The only way to do better is to use PowerCon 30A units. (Which no one has gear for) Anyways, very intentionally I choose those connectors. I wish there was an IEC unit with better grip, they are all kind of pathetic.
Quote from: Folsom on March 17, 2019, 11:18:45 PM
I'm not "hating" on anything.  I am disrespecting.  Hate is a worthless emotion with no positive outcome.  What I find hard to swallow is cheap, off the shelf wire terminated with junk connectors being marketed to gullible audiophools that are driven by hype.
The Neutrik 250VAC @ 32A is the finest connector available IME.  I am building a sextet Uber now with that connector this coming week.  I love 'me and they are relatively inexpensive.
Folsom
If you find the original posts about the cat and the cable they make it sound like the connectors are garbage.
The wire is confusing. I don't use particularly expensive wire, but it's the best stuff I think. It certainly isn't as cheap as $0.07 a ft or whatever that stuff is...
I have to agree with Dave. What I find most distressing about this is the just out and out sloppy workmanship put into what is being sold as a premium Audiophile product.
Folsom
Ya, there's no reason to be sloppy. Electrical tape is very tricky in a cable end. If there's any way to avoid it, it should be. Heatshrink is great stuff. But some insulation melts very easy. Also you can use crimp ferrules if the gauge isn't too big that you can't get the crimped ferrule in. Sadly you can't get most crimped ferrule sizes into the year plug clamp system.
That's one of my biggest gripes, weak clamp aystems. Most of them are pathetic in most plugs. They go limp and have to be retightened. A good builder will do it twice, but they're still bad. My fav connectors (found on the cat cable) can be wrenched really good. I come back and retighten but find they never come loose like the marincos etc. Some of the hospital ones are really bad. The worst I tried was a spring loaded one.
  Powercon for ALL . Time for Manf's to reconsider IEC.
Folsom
Quote from: rollo on August 15, 2019, 06:17:43 AM
Indeed. I've been buying ever IEC under the sun trying to find anymore I think are worth a damn. I mostly think it's bad design, but also that a custom one might be the only answer outside of manufacturers switching to Powercon (30A).
Quote from: Folsom on August 15, 2019, 04:08:41 PM
   A lockable or snap in IEC would be a blessing. For my personal use I have been considering using a PC with clips which would go through opening for IEC [ removed ] in chassis and clip directly to power inlet. No need to cut a hole for powercon. Kinda hard wired. For resale just reinstall IEC. Then no loose connection.
  My issue over the years was settling on a specific PC that offered no sonic signature which I have at last found.
Quote from: rollo on August 16, 2019, 10:27:33 AM
Sounds problematic to me. First off I am not sure what you would be able to clip onto and how good of a connection you would get with clips. But that you would have to listen to and see if the sound was better or worse. My bigger concern is one of safety. I am not sure what kind of clips you would be using, but if everything is just hanging through the IEC hole in the chassis it would not be very secure if the unit or the power cord ever got moved around for any reason. I could see the clips easily slipping off in that case witch would leave the clips, with live 120 volt power free to touch each other or anything within the component and cause all kinds of havoc......
You also will have to be very careful as to what kind of clips you use. Most clips are designed for use in low current situations. While they may be able to handle the power required to run a smaller component, like a DAC, you would need to be much more selective if working with a higher drain component, like a power amp.
I also am not sure how a connection with a clip would be more secure than even a flimsy IEC. Perhaps we are just not on the same wavelength on what kind of clips you envision using.
Off the top of my head, it seems like a lot more downside risk than potential gains, but if you want to experiment proceed with great caution.
