Linn LP12 Owners.
Started by rollo, October 26, 2007, 11:44:50 AM
Being a proud owner of a Linn Lingo, Ittock 2 arm with Cirkus and trampolin upgrades was wondering if I'm alone here. Any Linn owners with some input we can chat about?
PS; using micro Benz M2 and Loesch & Weisner phono stage/pre.
stereofool
Hi, Rollo!
I've also got a Linn LP-12. I certainly can't say I'm terribly knowledgeable, yet, but I do have several mods/updates that I need to do...one of these days. I've got some parts that have been sitting around for a couple of years, now.
YES...I AM a champion procrastonator  :roll:!!!
Steve
Lizard_king
The Linn LP12 is a very Musical LP payer!
Quote from: rollo on October 26, 2007, 11:44:50 AM
StereoNut
Hey Charles!
It's Bill.  I could just call you, but that would be too simple!  ;-)
Need advice... LP12 - Isolate or Couple??? That is the question!  Cones/Spikes/Footers vs. Sand Boxes, Air Bladders, Sorbothane, Raquetballs or anything else "squishy"?  Or... if you have a platform between the TT and the shelf on your audio rack, maybe a combination of the two???
Right now, I have a Sound Organization TT stand (spikes down to disks on the top of my Oak cabinet) with the MDF (?) insert board that the Sound Organization stands come with.  That insert board rests upon the upwards facing pinpoints that run along the inside rails of the stand, for a second coupling point.  I then have 4 metal cones (manufacturer?) under the frame of the LP12 to raise it off it's stock footers.
Can't decide on what's best or where to start!?
SN
Not an LP-12 experience , but........
A few months back I took the stock rubber feet of my VPI HW-19 and replaced them with cones. The change provided me with a noticeable positive improvement and the cones remain today. Will this work for an LP-12? Who knows? But I do know that the LP-12 have similar, but not identical types of suspension. Both sit on springs, but the LP-12 springs are a bit looser that the VPI. The different spring constants and resonance points may lead to different results, but the easiest way to find out is to try it. Luckily, this is a real easy one to swap in and out. If you have any kind of cones laying around a home just drop them in place and see what you think. If you like what it does you cam always look for "better" cones. If you don't have any spares I'm sure there is someone in the club with a few extras the can lend you.
Tom
StereoNut
Here are a few pix to show you what I have right now. (No extra charge for the dust and scratches!) It's been this way for a while now and I've been too lazy to remove everything and start listening all over again! I just thought there may be things I could do to improve the sound further.
I also have issues with a "springy" ceramic tile floor on a plywood subfloor over a crawlspace in regards to making my tonearm jump around if someone walks by. I'd never would've thought that having that much "mud" (whatever they call the concrete base they set tile in) would allow that much "bounce" in the floor, but it does. Maybe there's a way of getting away from being so sensitive to the floor issues and get better sound all at the same time!?
Oh, one more thing... I have to keep the "WAF" (Wife Acceptance Factor) in mind with whatever I do here!
Thanks!
SN
Ecramer
One of the best things you could do would be to take the spring out of the floor by running a beam under the floor joyces to take the spring out. This will also tighten up the bass
Second get  a sand box. to many cones doing to many things I build my sand boxes with a 3/4 mpf base dadoed into the sides 5/8 up from the bottom then another piece of 3/4 mdf Green glued to the first  to decouple vibrations
ED
StereoNut
Thanks, Ed!
Unfortunately, that floor is over a crawlspace. :(  The opening to get into the crawlspace is "a few sizes too small" compared to my not so svelte, "a few sizes too big" body!  It would be like trying to cram the proverbial "square peg in a round hole". :lol:
I like the sandbox idea.  Where would it work the best... directly on top of the oak cabinet, under the Sound Organization stand... or between the Sound Organization stand and the LP12 itself?  With cones, without etc...?
SN
Bill,
Have you ever given any though to wall mounted TT stand like the ones made by Target? They woufl certainly eliminate the footfall problem.
Music Direct carries a whole bunch of them.
http://www.musicdirect.com/category/245
Tom
shep
This is definitely the way to go, especially if you are lucky enough to have stone or brick or other "dead" wall. It eliminates the whole trial and error thing and frees up floor space. There's no need to get the expensive version if your wall is solid and vibration-free. There might still be some vibration transmitted to the wall if there are joists or beams running into it but that is really a minor issue.
StereoNut
Hi Guys
I actually have either a Target or Sound Organization wall mount TT rack stashed away somewhere.  I used it when my system was in a different room in the house, but the way the new room sets up there really isn't a place to put it.
Bill
bpape
Another option is to hang a platform on chains and springs from the ceiling.
StereoNut
Thanks, Bryan.
You either have a dedicated listening room all to yourself; otherwise be single or have a saint of a wife!  If I tell my wife I'm suspending my LP12 from chains and springs from the ceiling of the family room, I don't think I have to tell you what part of my anatomy will be hanging there right along with it... do I?   :shock: :(
What's "plan B" ???
SN
bpape
Hide it  :lol:
I don't have it any more but used to - and in my living room (yes, she's a saint).
Seriously, if you had a cabinet with an open back, you could build struts that stick out from the wall through the back of the cabinet and hang the shelf on that.
You need to get this guy to come over and rebalance the turntable, set the spring tension and dampening, level it all out and bless it with the Linn holy water. He charges by the hour and it takes about 3 hours to accomplish. Oh yeah, this only needs to be done once every 6 months and airfare and single malt are on you.
