Author Topic: Schiit new improved products.  (Read 6576 times)
Offline Guy 13
  • Audio should be simple !
« on: August 29, 2019, 04:24:51 AM »
Hi all.
Maybe some of you know already that Schiit came with a new improved Asgard 3 ?
In addition to the new Bifrost.
Guy 13
https://www.schiit.com/products/bifrost-1
https://www.schiit.com/products/asgard-1
Grace Digital Mondo RIT
Cambridge Mini sub 2.1
Schiit Fulla 2 DAC
Schiit SYS PCC
Lot more stuff on storage
Offline malloy
Re: Schiit new improved products.
« Reply #1 on: September 02, 2019, 07:35:57 AM »
Hi Guy,
This is news to me.
I have the Asgard 2. Good sound for very little money. I paired it with an HD 650. The only problem was the heat!
The whole casing is the heat sink. In summer, I cannot touch the case. Even the volume is too hot. Their site says 40-45 degrees C.
The Asgard 3 is not class A like the old ones, so they say it runs cooler.
Paul
Offline mresseguie
« Reply #2 on: September 02, 2019, 08:17:28 AM »
I don't have an Asgard. However, I do own a Lyr 3. It runs HOT - just like Malloy said of the Asgard. I took it to Taiwan for the winter to help heat my home office  :shock:, but last winter was so mild that it wasn't needed <as a heater>.
I've found my Lyr 3 to be a bit temperamental in that I must use an under 1 meter long USB cord, and cannot use my fancy 'audiophile USB cord. I use a cheapo $7 USB cord. Sometimes, my Mac Mini doesn't recognize the Lyr.
Malloy, have you experienced any issues with your Asgard's connectivity?
Michael
Don Sachs Model 2 preamp
Hapa loom
Offline malloy
« Reply #3 on: September 02, 2019, 10:29:14 AM »
Hi Michael,
My Asgard is the old version - headphone amp and preamp only, no dac module.
Strange that your Lyr can't drive longer length cables. Is it a matter of noise? Have you tried a reclocker such as iFi, Wyred 4 Sound, etc.?
Paul
Offline Guy 13
« Reply #4 on: September 02, 2019, 04:00:53 PM »
Hi all.
When in Canada next year I will buy the new Asgard with DAC module
to replace the Fulla 2 and the SYS.
I might also buy the Modi for the TV I will buy with digitl sound output,
my wife want to keep our old Pionner receiver.
Guy 13
Schiit Fulla 2 DAC
Schiit SYS PCC
Offline Guy 13
« Reply #5 on: October 06, 2019, 12:25:24 AM »
Hi Guy,
This is news to me.
Paul
Hi tmazz and others....
When I was shopping for an amplifier for my newly acquired Sennheiser HD650
I was considering the the Schiit Valhalla,
but here on planet Vietnam it's minimum 30C all years round
and with four tubes on the Valhalla
I was affraid that the amplifier would be hot like a gas stove
and in my thinking, heat is the worst ennemi of electronics.
So I went instead with the Bottlehead Crack,
still hot, but touchable.
Now I have Schiit Magni 3 run cool or just a little warm, can leave my hand on it.
But the problem, well, not really a problem, but for me it's more convenient
and less cables to have the Schiit Asgard 3
and I can eliminate the Schiit Fulla 2 and all it's cables.
Schiit says it run a little warm, but not hot.
The advantages of this Asgard is :
Will take less space, less cables, less heat (That has to be seen)
and according to many reviews (I don't always believe them) the sound
is better than the Magni 3, I will use the Asgard with both headphones :
Sennheiser HD-570 (60 Ohms) and HD-650 (300 Ohms)
and I have a pair of Panasonic small ear buds (Sorry no specs)
but at Amazon, they said they sold more than 50,000 units,
soooo... Can't be that bad.
As a matter of fact, for 10 USD they sound better than my wife's Apple ear buds.
Guy 13
Schiit Fulla 2 DAC
Schiit SYS PCC
