Musica Bella "Custom" twin chassis Class A balanced preamp - only $1,700
Started by Response Audio, November 20, 2019, 12:47:30 PM
Response Audio
We are currently underway on this build.
The Musica Bella twin chassis "Custom" is available in both single ended and fully balanced versions as well as your choice of our 6922/6DJ8 or 12AU7 circuit that has audiophiles all over the globe appreciating thier music collection. Will be built with 12AU7 circuit if now pre-ordered.
The power supply for the twin chassis "Custom" is the same size as the main chassis and designed to be stacked or placed side-by-side.
The Twin Chassis Version is Special
Being a seperate chassis, we will be installing our advanced power supply. The twin chassis power version power supply will be outfited with 100% polypropylene capacitors and choke filtered.
A relay based input selector takes care of the balanced and single ended inputs. ALL INPUTS and OUTPUTS  (single ended and balanced) are transformer coupled.
Transformer coupled balanced output. Like the inputs, XLR and single ended outputs transformers coupled.
HT bypass switch. We will leave tbis out or turn it into a high/low gain switch if ordered before completion.
Shipping included.
Retail value - $2,900
$1700 with minimum 50% down payment.
Response Audio NY
Custom Vacuum Tube Deaign
www.ResponseAudioNY.com
Response Audio
Parts are on their way. Front face plate for power supply chassis is hear.
Power supply will be built first to give potential customers a choice of line tube circuit.
I will post pictures here of the build as each stage is completed.
Response Audio NY
