P.I. audio group power conditioning thread...
Started by dBe, November 30, 2019, 10:14:56 AM
dBe
Tom Mallin is a customer of mine.  He has a dedicated niche in the What's Best forum and is a prolific writer.  His BUSS experience thread is a treatise on his experiences with the UberBUSS And the BUSS-Stop.  It is an interesting read and I'm quite pleased with his findings.
If you are interested:
https://www.whatsbestforum.com/threads/my-clean-power-adventures.28053/
Folsom
Quote from: dBe on November 30, 2019, 10:14:56 AM
He sure is! That's all the feedback one could ask for I imagine.
Triode Pete
Thank you, Dave. That's a very thoughtful and informative read from Tom and very much appreciated. I hope to have your latest AC outlet installed by the contractor this Tuesday.
dBe
Quote from: Nick B on December 01, 2019, 03:12:59 PM
:thumb:
  Good to read about someone who agrees. For years I have been advising to separate Digital from Analog with dedicated lines as described. Adding an UBER on each line further improves the Sound. Then adding that Buss Depot is the icing on the cake. I use [4] dedicated lines all conditioned. At least change your receptacles.
I am vacationing. When I get home, I'll be installing the new receptacles in my Uber 👍
Quote from: doug s. on January 16, 2020, 11:26:43 AM
i've not gone that extreme, but i have definitely gotten improved sonics from plugging my dac, transport and preamp into separate isolation transformers...
doug s.
Quote from: rollo on January 16, 2020, 07:56:02 AM
   Do not Isolation transformers lift the ground ?
Quote from: doug s. on January 17, 2020, 08:29:56 AM
i suspect those w/3-pronged plugs and outlets don't, but i'm not the expert.
doug s.
Quote from: rollo on January 17, 2020, 08:26:47 AM
doug s.
   They have a three prong plug however I believe the ground is lifted internally. Oh Dave help us out here.
HAL
Some Isolation transformers are floating output with a case wire to ground.
Others are 60v-0v-60v where the center tap of the output  is ground.
Folsom
Quote from: HAL on January 17, 2020, 10:07:03 AM
60/0/60 are balanced transformers.
The ground incoming to the transformer is often tied to the center tap. Maybe always, I haven't seen the inside of more than a few.
HAL
Yes, and from what I read, now no longer supported by the electrical code for home use.
I have an old Equi=Tech 2KVA balanced output unit that worked well before it died.  Very quiet system with it.
