amp recommendations
Started by Nick B, January 27, 2021, 08:08:09 PM
I'm thrilled with the sound I'm getting nowadays. But this hobby has me wondering...a little bit... how things would sound with a different amp. I've been using the tricked up ICE amp I bought from TomS. Had an on/off switch installed to get rid of a weird rt channel noise on shut off...probably emanating from my tube preamp.
The idea of a tube amp..or even another solid state .. is intriguing, but it would likely weigh more than I'd like. It's great to have my heaviest component weigh only 30 lbs (my Fritz speaker). Don't really have a budget in mind, but no more than $2,000
Anyway, thoughts/recommendations welcome.
What kind of power do you need to drive those speakers?
They're about 87 db, but pretty easy to drive per Fritz. I believe that is because of his crossover design. Iirc, he told me me he's run them with as little as 8 watts. I do tend to listen at high volume
Jack
Fritz and I own both own and think the Van Alstine SET 400 is a great pairing with the Carrera's and a tube preamp but if you don't want the weight (38 lbs) and size then the SET 120 at half the size and weight should do the job.
Vista Phono II Mk II
Jays Audio CDT3 Mk III
Supratek Chardonnay
Starkrimson 25s
Aqua La Scala Mk3
Auralic Aries G2.2
Verity Otello
(4) Rythmik F12SE
(2) Kinki Tai-Hangs
Veritas & TWL PC's
Jack,
Thanks for the suggestion, especially since I value your opinion and Fritz's  :thumb: I'll take a look. I'd prefer to keep the weight at 45 lbs or below. I can still handle that with my advancing years  :roll:
Jack
The SET 400 is really not that bad especially compared to my 88 lb. BHK 250 but the 120 is an alternative if you don't want or need the reserve power.
Supratek Chardonnay
Starkrimson 25s
Aqua La Scala Mk3
Auralic Aries G2.2
Verity Otello
(4) Rythmik F12SE
(2) Kinki Tai-Hangs
Veritas & TWL PC's
I'm up very late listening, and very much enjoying, my system. I've been thinking more about what I am really looking for in a new amp. My setup now is detailed, provides quite sufficient bass...maybe a teeny bit boomy at times, but hard to say whether it's related to the recording or the room acoustics. The treble is excellent and the timbre is much improved. With the cap and tube upgrades I've made, the sound has become more "organic". I would prefer a slightly smoother and richer mid and upper midrange and an even better presentation of the timbre. Do I absolutely need a tube or even a hybrid amp to achieve that, I have no idea. I am also open to the idea of an integrated as well, although my Audio Hungary 204 tube preamp with the nos Amperex 7308 tubes that Dave recommended is superb.
I will try and post some pics of my room as I'm open to some simple acoustic panels as well. Apple stores my pics as jpgs or jpegs and I think our forum software only accepts one of those formats. I'll try and get those pics posted later today. And I've upped my budget as well  :drool:  :duh
rodge827
#7
Check out the Digital Amplifier Company. I have had a number of his amps over the last few years, with  the last being a 2-Cherry. They are powerful and clean without any of the negative characteristics attributed to digital amplifiers. The closest sound to SET in a SS amp I've ever come across. I sold the DAC amp since I was able to score an excellent pair of 300b monos that I had always wanted. Are the 300b amps better? I'll just say that if I had the funds the DAC amps would still be around and some serious swapping would still be going on.
Reach out to Tommy at DAC he is a great guy to chat with and could make suggestions on which of his creations would suit you best.
https://www.cherryamp.com/
These are a very good deal and the seller is trustworthy:
https://www.audiocircle.com/index.php?topic=174490.0
"Those who stand for nothing fall for anything."
Alexander Hamilton
  An Audio Hungary Amp APR 200 with 100W/ch would go great with your preamp.
Quote from: rodge827 on January 28, 2021, 04:13:39 AM
Thanks. I'll check it out. I've seen some DAC posts at AC.
Quote from: rollo on January 28, 2021, 08:36:52 AM
Charles,
I'm sure it would sound very, very good, but it's 65 lbs and retails at $4,700 💰 :roll:
rodge827
Nick I forgot to mention that DAC offers a 30 day no frills return policy. You'll just be out for the shipping both ways.
Chris
Alexander Hamilton
Emil
    --Ice Cube
Quote from: Nick B on January 28, 2021, 02:45:34 PM
Charles,
  You will need an Amp Girl to help you.
Quote from: rodge827 on January 29, 2021, 04:34:42 AM
Chris
Thanks, Chris
