Vinyl cleaning machines
Started by Brap, February 01, 2021, 04:47:22 PM
Brap
Thinking about getting one.  Who has experience and recommendations?  Don't want to break the bank either. Rollo, you sell these by chance?
Fritz Carrera 7 Be
VTA ST-70
Parasound Halo P5
Oppo 105
Rega P3
Ortofon Quintet Bronze
Cambridge CXN streamer
Teac 3340S
Anticables 3.1
I have had a VPI HW-61.5 since 1988 and it does the job and  has never skipped a beat.
Yup, the VPI is probably the best and least expensive option. Sometimes you find them used for sale too. I highly recommend getting the disk doctor fluid and brushes to use with it.
#3
Quote from: Brap on February 01, 2021, 04:47:22 PM
  Yes the Kirmus. One of the best. Ultrasonic cleaning. Owned VPI sold after getting Kirmus. Differences heard. For the difference in price the extra for Kirmus is worth it.
I heard the results of the Kirmus at CAF and they were indeed impressive.
However, I have two big concerns with it. First the system relies on using the Kirmus proprietary Ionizing Surfactant spray. Perhaps I am a bit pessimistic, but who knows how long Kirmus will be around and according to the Kirmus demonstrations at CAF, that spray is the linchpin of the whole system. If it should become unavailable I'm not sure what kind of job the unit would do. On the other hand, the VPI and other similar machines will work just fine with any number of commercially available or home brew fluids.
Second, and more important to me personally, cleaning a record on the VPI is a 1 maybe 2 minute operation. Cleaning with the Kirmus involves 3 or 4  (or even more) cycles of a 5 minute ultrasonic cleaning and a two minute rub and scrub with the spray, and after all of this is over you still need to dry the record. Yes you can put multiple records in the bath at the same time, but they still each require their own 2 minute rub and scrub. Either way cleaning with the Krimus, even under the best of circumstances requires many multiples of the time it takes to clean on the VPI. I know myself and  while I do not mind spending a minute or two to clean a record before playing, if that time stretches to 15 or 20 minutes I will most often tend to just skip it. No matter how good a job a record cleaner does , it doesn't do any good if you don't use it.
All that said, the Kirmus system does a great job and if the points that I raised above don't cause you any concern then it would be an excellent choice for you.
Brap
Thanks for all the feedback thus far. Appreciate any more!.  Saw a VPI 16.5 used on the bay starting at $343. Sent questions, await answers.
Fritz Carrera 7 Be
VTA ST-70
Parasound Halo P5
Oppo 105
Rega P3
Teac 3340S
Anticables 3.1
S Clark
I clean no more than 2-3 minutes in an ultrasonic bath of 95% water and 5% isopropyl alcohol, and drops of surfectant.  I dry on an inexpensive Nitty Gritty to remove all solution.  It doesn't take any longer than just cleaning with the Nitty Gritty and it works vastly better.
Quote from: S Clark on February 02, 2021, 06:02:42 PM
  Good call no ritual needed.
This is just like everything else in this hobby.
You can pretty much always get some kind of improvement on anything with a application of additional time and/or money. And it is up to each of us to decide how good is good enough and when the additional effort and expense is just not worth it anymore.
There is no right or wrong answer to that question, just what works for you personally.
Brap
Yup - learning that lesson again. IT's a tough nut though based on my vinyl collection however, unfortunately lost a brother-in-law and he has quite the collection, many are master disc's which I may start to inherit. Golf season is approaching and for the VPI price, that's 13 weeks of tee times...........
Fritz Carrera 7 Be
VTA ST-70
Parasound Halo P5
Oppo 105
Rega P3
Teac 3340S
Anticables 3.1
