New Sub- Give Me Some Low Bass Stuff To Play With
Started by James Edward, February 08, 2021, 02:08:19 PM
James Edward
As title says... I listen to just about anything with the exception of modern country. Prog rock, rock, classical, jazz, rap, old country, etc. Just looking to hit up Tidal for some things to shake the rafters. Even better when it's real music. Thanks for any suggestions.
Jim
Chord Qutest DAC
Jim,
1) Fanfare for the Common Man - do a search and review track results (there are a number of well recorded versions)
2) Way Down Deep by Jennifer Warnes
Jack
Stanley Clarke, Larry Carlton, Billy Cobham - Live at the Greek.
Vista Phono II Mk II
Jays Audio CDT3 Mk 3
Aric Audio Motherlode XL
Erhard Elvis Mk2
Aqua La Scala Mk3
Auralic Aries G2.2
Verity Arindal
(4) Rythmik F12SE
(2) Kinki Tai-Hang
Veritas & TWL PC's
Bob in St. Louis
Olive "Indulge Me"
https://youtu.be/uhWzeF5HVGg
Bela Fleck "Flight of the Cosmic Hippo"
https://youtu.be/Tt_22fXoDYs
Trust me, as a bass fanatic, these two are incredible. Not sure if these YT links are getting the message across.
But suffice it to say, that if you get the correct versions, it'll vibrate the hairs on your body.
If you're set up right, it'll vibrate your clothing and feel it in your chest. (recording dependent, of course).
Quote from: Bob in St. Louis on February 08, 2021, 07:52:08 PM
Olive "Indulge Me"
That whole UFO Tofu Bela Fleck recording that The Hippo comes from is an awesome recording for LF, dynamics and percussive banjo.  Futureman's Synthaxe Drumitar has some great effects, too.  One of my all time faves for bass... Victor Wooten.
Bob in St. Louis
#5
Oh yea, Wooten is great too!
Speaking of bass, the "WOOD" and WOOD II albums from Brian Bromberg has some nice bass to it as well. Not the ultimate visceral gut punch true test of a subwoofer, but should tell you if you've got a "one note sub" or not.
Here's one tune: https://youtu.be/TgOWa-RdL9Y
By the way, I've heard some versions of the "Hippo" that were actually pretty bad. I think it was the live ones?
StereoNut
Clarence Clemons - Peacemaker
There are a couple of cuts that have some real good bass.
SN
#9
I don't know if these two fit your criteria James, but the deep bass is certainly there.
Here is real pipe organ, Pictures at the exhibition. I see one selection that is 33 minutes long.
https://www.youtube.com/results?search_query=picture+at+an+exhibition+mussorgsky+jean+guillou+cd
Titanic used a notched 64 foot pipe for the very deep bass.
https://www.youtube.com/watch?v=QcBfwJ06Jpk
Maybe this one by Paul and Paula?
https://www.youtube.com/watch?v=6vOo-3XWxpo
A little Pink Floyd
https://www.youtube.com/watch?v=sxo0OJkbaMY
https://www.youtube.com/watch?v=cVBCE3gaNxc
A little BTO
https://www.youtube.com/watch?v=FhnSiRYPqpw
Mimir Modified DAC
SAS 20 W Ref Triode 40 W UL
Bob in St. Louis
Because of this thread, I went through an old "audiophile playlist", and thought I'd share these.
You might want to sneak up on this one, the bass is pretty strong.
Terje Isungset - Fading Sun - https://youtu.be/dONSkfbxnao
Chris Jones - Long After You're Gone - https://youtu.be/D-h6MoF7HLA
I'm adding this one, as it has enough bass to be given an honorable mention here.
Beyond that, it's JUST FUN.
Cyrill Lutzelschwab & Martin Hess - https://youtu.be/CZUBvBJWYVc
Oh, yeah.  I forgot:
Pete Belasco - Deeper
21Hz - 808 drop... it is a pant leg shaker for sure!
Bob in St. Louis
#14
Quote from: Bob in St. Louis on February 09, 2021, 06:33:06 PM
Quote from: P.I. on February 09, 2021, 06:28:59 PM
Oh, yeah.  I forgot:
https://youtu.be/eaYQuHV6b4g
Thanks Bob.  I got interrupted and forgot to add that link.  :thumb:
IIRC the precise frequency is 20.6Hz or E0
