Treating Speaker Driver For Ringing
Started by James Edward, March 02, 2021, 02:40:11 PM
James Edward
Good Afternoon,
As some may know, I use Spatial Audio M3 Turbo S speakers, and I'm quite happy with the sound. But, since this site uses the word 'nervosa', and I am certainly afflicted, here goes...
It is an open baffle design, and the drivers use stamped baskets. I've never heard ringing from them, though how sure can one be? Nervosa.
Being open baffle, the speaker frame is easily accessible. I was thinking of using Dynamat, or a similar substance on the frame. These speakers use modified pro audio 15" drivers from Eminence. I know I can just try it and see, but some of these products aren't cheap.
Then my nervosa kicked in again and wondered- maybe I would kill the sound I love by deadening the frame. But I hardly think Eminence drivers are designed like some British speaker cabinets designed to flex and add to the overall character of the speaker.
Thoughts appreciated.
Chord Qutest DAC
S Clark
I would bet that Spatial has waterfall plots if you email him.  Otherwise, you have nothing to lose by deadening the frame of the woofers, maybe nothing gained, but no harm done.
Folsom
I think Ron measured them at NRD.
Also I highly doubt you'd gain anything by doing this.
I have used caulking cord for years on stamped baskets.  It is called Mortite.  Here is a link:
https://www.amazon.com/Frost-King-B2-Caulking-19-Ounce/dp/B000LNODSQ/ref=sr_1_3?dchild=1&keywords=mortite+caulking+cord&qid=1614744792&sr=8-3
Use into the inside of the basket that faces the cone.  It will reduce ringing... a lot!
Jim,
You won't be out a lot of 💰 for Dave's suggestion
I have use Mortite on a number of projects. Not only is it cheap to try, but it stays soft and remains easy to remove long after you put it on.
It did a great job for me damping out vibrations in a CD transport mechanism.
And BTW, it also does a nice job at sealing up drafty windows, which is its original purpose.
James Edward
I'm so glad I asked. Mortite is a great idea- I too use it around the house. There happens to be a box already in-house. Thanks!
Chord Qutest DAC
  You can give it a try. However may be an issue removing it if you decide to sell them. If it ain't broke don't fix it is mt motto. Your Nervosa is warranted however in this case leave them be.
Quote from: rollo on March 03, 2021, 10:03:33 AM
The Mortite caulking cord can be easily removed without a trace...
James Edward
Another reason I'm glad I asked the question here- yes, Dynamat would also work, but Mortite is dead cheap. Per what Charles said- another good reason to use Mortite- it is easily removable, whereas Dynamat uses an adhesive that is surely more aggressive.
I'll have to spring for another roll in a dark color- the backs of the speaker are visible.
BTW, anyone reading this thread, Mortite is pretty much a cheap alternative to the audiophile approved, and oft mentioned Blu-Tack.
Chord Qutest DAC
_Scotty_
#10
James, being the lazy person that I am, I was thinking you might try to see if you have a ringing basket on the driver before you go to the trouble of treating it. Assuming that the basket is readily accessible, you might take a metal spoon and tap legs of the basket to see if it will ring like a tuning fork or not.
Obviously if you can't make the basket ring with a direct application of physical force from the spoon
it is unlikely that acoustic energy from the speaker cone will be able to induce any ringing.
Now that your Nervosa is fully engaged you could consider if there was any midrange frequencies
being reflected back through the speaker cone from the legs of the basket due to their width and surface area.
A partial solution to this potential problem is to put a 0.3 to 0.5 inch layer of fairly high density felt on the side of the basket leg facing the speaker cone. It might make a small improvement or not. There is a potentially larger problem from reflected sound emanating from spider area and surrounding metal outside the perimeter of the
spider. No speaker driver is "perfect" and some compromises always have to be made in order to meet the goal of getting a product to market.
Quote from: _Scotty_ on March 04, 2021, 12:18:49 PM
Lazy but one smart cookie. Great advice.
James Edward
Oh, it rings. And it's magnetic. The first few items I tried just stuck to the frame by magnetic force. After getting the appropriate implement, it does indeed ring.
The dark mortite has arrived, and that'll be this weekend's audio project.
As for what Scotty said- I direct you to  'The Bass' bullet point in this link- he also mentions higher frequency reflections. I was proud of myself for coming up with the ringing idea, but this guy takes it to a whole other level. The Emerald Physics speakers are similar in configuration to my Spatials- they share a certain bloodline as it were...
http://tweakaudio.com/EVS-2/Modding_the_Emerald_Physics_spe.html
I have felt too. I'm going to do one thing at a time though.
The irony in all of this- I love the sound I'm getting now. As a bumper sticker I saw once said- 'If it ain't broke, fix it until it is'.
Chord Qutest DAC
James Edward
So... Rather than wait, I applied Mortite string caulk to the ribs of the speaker drivers. Since I don't have enough Mortite, I was able to compare. The 'treated' ones are lower in frequency when dinged than the untreated ones. Hopefully that is positive. Not being a brainiac, I'm not 100% sure. I'll go with the chicken soup theory- it can't hurt.
Truthfully, I don't know that this will translate into better sound, though it can't hurt, and I will sleep better. An example- I drive for a living, and heard an hour- long interview regarding this- simple, incremental changes.
https://productiveclub.com/marginal-gains/
Commander Cody on the stereo now. Must go turn it up!
Chord Qutest DAC
Quote from: James Edward on March 10, 2021, 02:45:48 PM
That is a rather amazing article. Thanks for taking the time to post it.
