Determining Crossover Slope?
Started by James Edward, March 13, 2021, 11:09:49 AM
James Edward
I have pics of a crossover that I'd like to identify the slope of. If it's possible that someone here might know, I can PM the pics. Thanks
Jim
Chord Qutest DAC
  Send it to Danny at GR Research. He Da Man.
HAL
If you post the pictures of the crossover, that would work to identify the style if it is simple.  If not, measurements would be needed to identify the electrical crossover slopes.  Even with component values, you need measurements to see the response.
James Edward
I've never successfully posted pictures here. They either get rejected for wrong file extension, or they're upside down, or whatever. Always frustrating.
Chord Qutest DAC
HAL
I just use Paint to resize the pictures below the 600KB limit and that always works.
Jim,
I'm not sure if I previously posted on this or not, but I use Apple and they use jpeg or jpg..not sure. I think this site likes the opposite. It's interesting when I copy and paste pics from Amazon re the " what am I listening to now" posts, it works perfect every time. Jim, are you an Apple user?
HAL
Nick B,
All my pictures are *.jpg format JPEG's pictures even with Windows 10.
Quote from: HAL on March 16, 2021, 01:40:55 PM
Nick B,
Thanks, Rich.
I'm going to look into it more as I'd like to be able to post pics from my library, just not the internet. My pic skill level has always been more toward a Brownie than a Hasselblad
James Edward
Quote from: Nick B on March 16, 2021, 01:05:06 PM
Jim,
Yes, jpeg extension not allowed was the last message. I've gotten some suggestions from members and will be trying again when I have some time. FWIW, which is probably nothing, I tried a PM to a member and it was the same message. I will figure it out eventually... Thanks to all.
Chord Qutest DAC
Quote from: James Edward on March 16, 2021, 03:56:33 PM
Jim,
As soon as I figure out jpeg/jpg conversion (or should I say if...), I'll let you know  :lol:
HAL
Try just renaming the file from *.jpeg to *.jpg and see what happens.
