Author Topic: Help Choosing Shrink Tubing  (Read 4902 times)
Offline James Edward
« on: April 21, 2021, 01:22:34 PM »
Yes- my soldering adventures continue... Jimbones has helped me choose capacitors and tweeters for a project- now I’m about to get some shrink tubing. It would be for our hobby- speaker wire, etc. As usual, too many choices- companies, sizes, etc. In the old days, RadioShack and done.
If possible, please take a look here and recommend something. I’m old and won’t be using much, so a a smaller amount is fine. I’d rather go for quality than quantity.
https://www.amazon.com/s?k=shrink+tubing&ref=nb_sb_noss_1
Thanks.
Esoteric K-07X
Re: Help Choosing Shrink Tubing
« Reply #1 on: April 21, 2021, 01:50:16 PM »
I should say that if those in the know believe they’re all the same, that’s fine too. I’m not averse to just winging it...
Esoteric K-07X
« Reply #2 on: April 21, 2021, 02:28:32 PM »
Got my answer. Thanks for looking.
Esoteric K-07X
« Reply #3 on: April 21, 2021, 03:04:30 PM »
You found something on Amazon?
Offline Folsom
« Reply #4 on: April 21, 2021, 06:29:54 PM »
Wirecare
