Beefing Up An Old Speaker Cabinet
Started by James Edward, May 10, 2021, 07:06:31 PM
James Edward
I'm helping a friend refurbish a 40 year old pair of SEAS speakers. I had SG Custom Sound rebuild the crossovers, and consulted with Madisound about replacement drivers which are on the way.
The cabinets themselves seem a little 'ringy' to me. Since the crossovers are finished, and the drivers are spec'd for the original cabinet dimensions (it's a 2 cabinet design, a little like a WATT/Puppy), what options are available to deaden the box? I would imagine much internal bracing would alter the volume- is this much of a concern? The woofer cabinet is ~ 59 liters.
Would a Dynamat product be a solution? Or am I overthinking this? Would a few crossbars inside make much of a difference to the box volume to affect much of anything?
Any thoughts or suggestions appreciated. My friend is a carpenter and craftsman, so most ideas could probably be implemented without much trouble.
Thanks as always.
Chord Qutest DAC
Jack
Might want to ask Danny at GR Research.
Vista Phono II Mk II
Jays Audio CDT3 Mk 3
Aric Audio Motherlode XL
Erhard Elvis Mk2
Aqua La Scala Mk3
Auralic Aries G2.2
Verity Arindal
(4) Rythmik F12SE
(2) Kinki Tai-Hang
Veritas & TWL PC's
S Clark
Crossbars would have a negligible effect of the volume and are usually a good idea ( I like dowel rods).  For damping side walls, the No Rez that Danny sells is a good product. It also has little effect on internal volume, since it is mostly a very dense open cell foam.  It does need a clean surface to stick.
Quote from: S Clark on May 10, 2021, 08:31:23 PM
  Sound advice. Agree 100%.
James Edward
Just a follow-up… I’ve settled on this- it will serve to beef up the box a bit and also eliminate the need for the fiberglass insulation, resulting in a neater project.
https://www.parts-express.com/Sonic-Barrier-1-1-4-3-Layer-Damping-Material-w-PSA-18-x-24-260-535
My friend still wants to refinish the cabinets, but the crossovers are rebuilt, and the speaker drivers are in. I’ll post some pics when these babies are singing. I should say I’ll TRY and post some pics!
Rebuilt crossovers done by Scott at SG Custom Sound Douglaston, NY
Drivers from Madisound- Brian was VERY helpful in getting drivers that fit and corresponded to the original T/S parameters.
I guess the proof will be in the pudding when these are finally together.
Chord Qutest DAC
Quote from: James Edward on June 12, 2021, 02:08:25 PM
Just a follow-up... I've settled on this- it will serve to beef up the box a bit and also eliminate the need for the fiberglass insulation, resulting in a neater project.
My friend still wants to refinish the cabinets, but the crossovers are rebuilt, and the speaker drivers are in. I'll post some pics when these babies are singing. I should say I'll TRY and post some pics!
Yes, pls keep us posted. As to posting pics, I feel your pain... I'm able to post online pics, but none from my iPhoto library....  not yet at least  :lol:  the old heic, jpg, jpeg problem
  Decent choice however No-Rez is King in that department. I would install wood dowels forced into place to stiffen cabinet. Have fun.
James Edward
They are finally together- after two years! I'll figure out a way to get some pictures on here. They sound good too- props to SG Custom Sound for the crossovers, and Madisound for all the back and forth regarding drivers that would fit both the cabinet and original specifications- these were purchased in 1980!
A little tung oil rub and the cabinets don't look too shabby either.
Thanks to all who gave suggestions.
Chord Qutest DAC
Quote from: James Edward on May 02, 2023, 07:20:42 AM
Great news! Would enjoy seeing the pics. Any idea what format the pics you'll be posting are? jpeg,jpg, heic...?
S Clark
Quote from: Nick B on May 02, 2023, 09:56:46 AM
+1
