placing my Fritz Carreras
Started by Nick B, May 15, 2021, 03:15:08 PM
I've really never given speaker placement much consideration. Have been in my current house for nearly 18 years and for 15-16 of those years, I had a very large and very heavy cabinet that housed my equipment including my turntable and my 400+ CDs. Finally was able to consign the cabinet and have the flexibility to now move things around a bit.
As my Fritzies weren't fussy as to placement per Fritz Heiler, I just had them out 14-16" from the wall. I recently experimented a bit and now have them out an additional foot or so and what an interesting and nice improvement. There's more soundstage depth, but there's also more focus, less "congestion" as the reviewers might say. Individual voices in a chorus are more distinguishable, the treble is a bit cleaner and the midrange is a bit richer. I don't care that much about bass and am still troubled occasionally with a bit of boominess. I'll tackle that problem soon...
My living room is asymmetrical and the left speaker now is 3' from the side wall and maybe 2 1/2 - 3' from the front wall (I can't measure now as I'm vacationing). I should mention that I have a hinged, small 3 piece room divider that I placed in that corner so it's not 90 degrees. The right speaker doesn't really have a side boundary wall as the space goes through the living room and into the guest bedroom opening. So it's just fascinating to me how a relatively small change in placement can make such a nice improvement  :thumb:  Much more experimentation will follow when I get home.
Jack
That sounds about right Nick.  Mine are 42" from the wall behind them measured from the front baffle.
Vista Phono II Mk II
Jays Audio CDT3 Mk III
Aric Audio Motherlode XL
Erhard Elvis
Aqua La Scala Mk3
Auralic Aries G2.2
Verity Arindal
(4) Rythmik F12SE
(2) Kinki Tai-Hangs
Veritas & TWL PC's
Jack, for ease of measuring, my points of measurement are the rear inside
edges of the Fritzies (facing the equipment rack) and rear outside edges.
There is very little toe in right now ... the difference being about 1 1/2 inches from the wall.
Jack
We're probably within a few inches of each other then.  With the room they are in in Greenville I can come out further just haven't seen a reason to.  Never been a fan of much toe-in.  Usually start out straight ahead and then if need be try a little at a time. As that room is narrower than I have been used to they are only 7' apart center to center so close to straight ahead works well.  Need to swap them back in when I get back Monday. Last time I was there I swapped the Reynaud's and Harbeth's back and forth the whole time.
Erhard Elvis
Aqua La Scala Mk3
Auralic Aries G2.2
Verity Arindal
(4) Rythmik F12SE
(2) Kinki Tai-Hangs
Veritas & TWL PC's
I think I'm about 7' apart on center and sit back about 11'.... a very nice isosceles triangle
Jack
Pretty much the same and due to the lack of width with that room 7 feet on center is the best I can do with any speaker without getting to close to the side walls. About 2 1/2 feet is the best I can do to the sides and with the C7's it's a bit less due to their width.
Erhard Elvis
Aqua La Scala Mk3
Auralic Aries G2.2
Verity Arindal
(4) Rythmik F12SE
(2) Kinki Tai-Hangs
Veritas & TWL PC's
  Try 9' apart if you can. toe in to just outside your shoulder. I like 4' from front wall. Then move your listening chair back and forth to find sweet spot. Have fun.
Quote from: rollo on May 21, 2021, 07:46:47 AM
I wish I could go further apart. My guess of 7' apart is off and I'm actually at less than 6' from the center of the drivers. Maybe I can move the left speaker a little bit more toward the side wall. Its currently 24" from the left edge of the Fritz. It's a living room with a walkway to access other rooms.
 Try nothing to lose everything to gain.
