And she's got a great personality
Started by dflee, July 19, 2021, 10:59:54 AM
dflee
For a guy going on a blind date those words always put that "what did I get myself into" thoughts.
I'm finding the same when told "the bass is clean, fast and tight". Seems that with those words then
the room pressurizing thump in the chest type LF may be missing. Yes in some cases I found that statement to
be true in the aspect that it is there but just not THERE. Would you not get a drawn out note (not tight) in order
to have that kind of authority in the lower region? It may take mucho dinero to get both (that I will probably
never hear) or is it just not possible to have both?
Don
Jack
All depends on how much you think "mucho dinero" is
Vista Phono II Mk II
Jays Audio CDT3 Mk III
Aric Audio Motherlode XL
Erhard Elvis
Aqua La Scala Mk3
Auralic Aries G2.2
Verity Arindal
(4) Rythmik F12SE
(2) Kinki Tai-Hangs
Veritas & TWL PC's
One more time: subwoofer.
You seem to be treading water with a speaker that meets your wants.  From everything I have seen you are looking for more bass than is, uhm...real.
You want LF "hit", buy the thing that will do 'it' for you.
What size subs will fit into your room?
Jack
If your plan is to still "start from scratch" with new speakers as you said in an earlier thread you either have to get extremely lucky on the used market to find a floor stander that will fit your bass wants and not drive you out of the room or find a monitor that delivers for you from the mid 40's and up then fill that it with a pair of subs.  I use Rythmik F-12's but there are others that will fit the bill. For a change of pace in my Main system I replaced the full range Verity Otello's with a pair of $2500 Reynaud Bliss Jubillee's. They are a transmission line book shelf speaker that will reach the low 40's on their own.  I then dialed up the crossover on the Rythmiks from the 35hz point used with the Verity's to 60hz and I still have great sound with all the LF response I need.  The most important thing is to find a speaker whose sound you can live with for long periods and then deal with the low frequencies by other means.
Erhard Elvis
Aqua La Scala Mk3
Auralic Aries G2.2
Verity Arindal
(4) Rythmik F12SE
(2) Kinki Tai-Hangs
Veritas & TWL PC's
#5
Quote from: Jack on July 19, 2021, 08:28:25 PM
Rythmik subs are amazing for a sealed sub.  Brian's sensing coil servo control is orders of magnitude better than accelerometer based subs.  The apparent speed and impact is only challenged (@less than $3K) by GR open baffle subs.  Those are still my favorite for tuneful, easily integrated LF.  -3dB in-room in the 'teens.  :thumb:  Yowza! There is a reason GR rooms were chosen every year at RMAF when we (GR, P.I., TWL, Dodd Audio, dB Audio Lans) were exhibiting back a few years ago for "Best bass."  Steven Stone's Best Sound of Show a couple of times was pretty cool  :thumb:
Barry (NJ)
Nothing beats a good pair of speakers with a well integrated sub-woofer...
dflee
I guess I misspoke somehow.
The question was is can you have both, clean tight fast LF and still have
the authoritative bass. Wouldn't it have to linger in the room and thus be slow(er)
and not as clean?
Don
Quote from: Barry (NJ) on July 20, 2021, 05:32:24 AM
.... except perhaps a pair of good speakers that doesn't need a sub?
Of course then you are probably talking $$$$.
Quote from: dflee on July 20, 2021, 04:28:44 PM
and not as clean?
Don
To get what you are calling authoritative bass you need to move a lot of air. The most common way to do this is to use a big driver with a long throw. But this comes with its own set of problems. A big driver adds comes with a lot of moving mass. When you apply a + signal to that drive  it will move forward gaining inertia as it travel. When the signal switches polarity to _ the driver should immediately reverse direction and start traveling backwards. But because of the inertia gained by the cone the first few milliseconds of negative signal ends up acting as a brake and slowing the driver to a stop before it can begin traveling in the opposite directions. What you are sensing as the bass lingering in the room is actually the sound of the cones inertia. causing it to overshoot the point where it is supposed to change direction. This can be address in several ways, unfortunately all of which involve added costs.
You can make the cones out of some exotic (i.ie. expensive) lightweight material to lower the moving mass. This will help, but only get you so far.
You can employ some kind of feedback system that measures the speed and direction of the cone, compares it to the signal driving it and modifies that signal to add some extra "braking voltage" to counteract the inertia. This is commonly referred to as a servo system and while it can be effective it also adds extra circuitry to the system hat increases the cost.
And you can also lower the inertia by employing multiple driver. With multiple drivers the cones do not need to travel as far because each driver needs to move less air. The shorter throw means the cone builds up less speed and is easier to "turn around".   The easier turnaround leads to less overshoot and therefore a tighter sounding bass. Taking this one step further, using multiple driver also gives you the opportunity to use smaller driver which have less mass and therefore less inertia and less overshoot. But more driver means not only more parts, but bigger cabinets and once again more cost. The best subs I ever heard were a pair of towers that each had if I remember correctly 6 five in drivers. Bass that kicked you right in the chest and as tight as I have ever heard. The dealer told me that the six drivers working together has the same air moving capacity as a 15 inch woofer but they only moved back and forth about 1/2 inch in either direction. But of course the price tag on then was $4500 in 1988.
So Don you were correct in that good bass is not cheap, but at least I hope you have a little better understanding of the hows and whys.
And I know there are others in our little circle that have more speaker design experience that me, so if anyone wants to jump in and add more detail or even correct something that I may have misspoken about, feel free, no offense take, I'm here to learn too.
When I got my Boxers I asked Carl at Nola what he recommended in the way of a sub since at the time Nola had stopped making them. His only advice was to get one with the smallest driver I could find because with the 6.5 inch woofer in the Boxer a 12 sub driver would never blend right and I would always end up hearing the speed difference between the bass from the speakers and the subs. In his mind a small quantity of good tight bass was better than a larger amount of loose sloppy bass.
I got a pair of Sunfire True Subwoofer Super Jrs. with 8 inch drivers and have been very happy with them. Of course that is because the blend very nicely with my speakers. As usual YMMV.
The concept of using multiple, smaller drivers is interesting, but I've not understood at what point that concept would no longer hold up. If you can move a lot of air and get great bass with a few 6.5"s, then can you get tight bass by using even more 5"s or 3.5s? Is there not a point where the driver, not matter how many you use, can simply not move enough air?
Quote from: Nick B on July 20, 2021, 05:46:02 PM
I guess theoretically no, but I would think that at some point you would hit a point of diminishing returns, or when is tight tight enough? and b) you would probably hit a point where it was just not practical anymore. I would think as the drivers got smaller you would run into a situation there stepping down to the next smallest size would require A LOT more drivers and it would become not only cost prohibitive but just kind of silly. As you get into smaller and smaller drivers not only does the area decrease, but also the length of the throw and therefore the amount air air they can move. As you can imagine a 1 inch silk dome tweeter cannot move a very large amount of air, so while you could put enough of them together to reproduce bass with them would anyone really want to build a sub with say 100 tweeters ( I don't know that 100 is real number required, but you get the idea.)
The problem you run into with small drivers is that they do not have low enough resonant frequencies necessary to produce low bass, unless they are used in what is called and ELF alignment.  ELF subwoofers can produce great lows but require prodigious amounts of power to counteract the low frequency roll offs that occur below resonance.
It is physics raising its ugly head.  Like Tom said to produce lows with authority requires a lot air must be moved.  This requires high stroke volume.  Either a large diaphragm must move a little or multiple small drivers with low resonant frequencies must move a lot farther to move the air.  Peter Noerbaek regularly uses dual 18" woofers in his large speakers.  They have an effective cone area of ~188 sq in each with an Xmax of 1".  This means that the maximum linear excursion of each speaker is 2".  Doing the math for low frequencies (usually mixed in the middle in recordings) is: 188 x 2 x 4 = 1504 cu in per excursion at Xmax.  Find a 6.5" driver with a very low resonant frequency to produce the same LF response.  They exist.  Let's do some math again.  Most 6.5" subwoofers have an effective cone area of ~ 19 sq in and an Xmax of ~1/4".  They would move about 9.5 cu in of air at Xmax.  This means it would take 167 of those woofers to move the same amount of air as those 4 - 18" drivers.
In cars and low frequencies there ain't no substitute for cubic inches.
Quote from: P.I. on July 20, 2021, 10:50:58 PM
Thanks for the math lesson, Dave. I like it when you crunch the numbers like that. Bass has never been all that important to me because of the type of music that I normally listen to and what I think are significant room limitations in my open plan living room.
Twenty years ago I owned the Shahinian Diapasons which I believe have two 8" drivers on the sides of the bottom module and a passive 12" on the rear. It sure would be nice to experience what a 12" or 15" sounds (feels) like 💥
