Keep It Simple or NOT ???
Started by rollo, December 22, 2022, 12:44:51 PM
  Recently I have thinking about going to an integrated Amp instead of Preamp mono blocks. Weighing the benefits and disadvantages of both. Always was a dual mono Guy from source to speaker. Using a dual mono DAC which will remain. My previous experience was a smaller soundstage and imaging with integrated. I would need minimum 150W power.
  What are your preferences ?? and experiences ??
GDHAL
#1
Quote from: rollo on December 22, 2022, 12:44:51 PM
Hi Charles. Happy holiday's.
I have no personal experience using separate components. I've always used an 'integrated" solution.
The benefits of integrated include less physical space, and most likely less cost. Also less miscellaneous considerations such as cable connectivity, impedance matching, etc.
The disadvantages are, as you're already aware, integrated for whatever reason (valid or not) does not meet ultra-hi-end-criteria in terms of what can be achieved sonically.
These days there are many outstanding choices for an integrated amp. And, like most other things in life, ones budget and financial considerations play a role in your purchasing decision.
As to your 150 watt power requirement, that too can questioned because amplifier power necessity should take into consideration how efficient your speakers are, and the sound pressure level that you prefer to listen to music.
If you provide more detail, I can provide more specific recommendations.
Best.
Hal
http://halr.x10.mx/other.html
S Clark
I've sort of split the difference in one system.  Gary Dodd built two mono integrated amps for me years ago.  At the time, it was the best option for a bedroom system that my wife could access.
ejk
Rogue Sphinx V3. Class D with tube front end. Power,dynamics and transparent. The Pharoh II also gets fantastic reviews and ups all the above
DRN
I think I'm  going on 5  years now with my Rogue CM 2 no complaints very happy. It does weigh in at 60 lbs with the cage.  :roll:
Absolutely keep it simple!
Rogue CM Dark 2 SVS SB2000Pro Sonus Faber Sonetto 2  CA Emotion SE CMB Carbon Satisfy Arm Phoenix Falcon PS
Hanna ML Shelter 501 lll
Hagerman Trumpet mc3 Nos tubes
Belden 8402 Duelund 12ga SC
Yggdrasil+LIM CECTL5 Trans
Wiim ultra Qobuz
Surge x power
TopRound‎
Hal
I have 4 preamps you can borrow to try, see what they do for you good or bad
Personally I have found preamps to be a critical part of a system, they can have a great affect on a system, good or bad.
You have to find the right one for your system. Yes an integrated is an easy solution, but it does have a preamp function built in.
A separate allows you to tailor, and it could be a great benefit
I'm a tube guy so they are tubed , but tubes infront of SS usually is pretty nice :thumb:
System: Nothing....gave it all up, but building a few things for my kids...vinyl, tubes and Gan Fet!
GDHAL
#6
Quote from: TopRound‎ on December 22, 2022, 06:12:00 PM
Hal
I appreciate the offer, Mike. Very kind of you.
Of course, I realize an integrated has a preamp section, and the preamp is extremely important to sound character. I'm rather content with my Musical Fidelity M6si, which is dual mono configuration. And, I can connect a separate preamp to it and use it as just a power amp.
Thing is, I'm not the one contemplating making any kind system change. Charles is  :D
#7
Hi Charles,
I would attempt to audition any and all integrated amps in your home in your setup first and compare. Please
take your time as first impressions may not leave a good lasting impression. I don't know how many times I
have read/heard of some one exchanging one setup to another and wishing they had their original setup.
Mimir Modified DAC
SAS 20 W Ref Triode 40 W UL
TopRound‎
I think we're all guilty of selling a piece of gear we wish we kept!
Emil
At this time in my audiophile journey, its integrated amps for me.
Currently enjoying my Belles Aria Signature
    --Ice Cube
Lonewolfny42
Quote from: Emil on December 23, 2022, 05:59:29 AM
https://youtu.be/6iv2t9SErkA
"Refuse To Be Misused" Harlots of 42nd. Street
Emil
Quote from: Lonewolfny42 on December 23, 2022, 08:18:28 AM
Hey Chris!
Mine is the SIGNATURE version :mrgreen:
    --Ice Cube
Folsom
An integrated could technically be monoblocked internally.
GDHAL
Quote from: Folsom on December 23, 2022, 06:02:22 PM
As is mine.
Plus, if you have a spare $30k give or take, you could get among the best on the planet (nowadays, who knows what tomorrow will bring).
https://www.german-physiks.com/emperor-integrated-amplifier
Quote from: GDHAL on December 23, 2022, 06:13:19 PM
As is mine.
Very interesting, Hal. I thought that company only made speakers.
