Maestro AC Outlet
Started by Emil, January 09, 2023, 10:17:58 AM
Emil
https://www.cruzefirstaudio.com/maestro
90 bucks. Why not?
Well I'll be damned. This made an audible difference for the better!
Quieter background. Tighter bass. Smoother, more musical presentation.
Power of suggestion? Dunno. I can remove it and reinstall the heavy duty looking Levitan outlet I had but that's a pain in the ass. I'm enjoying what I'm hearing even if it is.
    --Ice Cube
GDHAL
I can believe that it made an improvement, especially if the previous outlet / plug connection was loose.
Many favorable reports about Maestro outlets (subjective anecdotal evidence if you will) can be found on other forums.
Best of luck with them (or it if only one). :)
http://halr.x10.mx/other.html
  Yes they can make a difference. PIAudio makes a VG one. Furutech though is my favorite. The VooDoo all copper is VG as well.
James Edward
I also believe in the power of the outlet. PI Dave was good enough to send me one a while back and Tmazz summed it up nicely... I don't know if I'd believe it if I hadn't heard it with my own ears.
https://www.audionervosa.com/index.php?topic=8482.msg106736#msg106736
Chord Qutest DAC
  Yes PIAudio one is VG. Similar to Rhodium. A neutral presentation. Furutech Gold over copper is warm, all Copper a tad bright. I have compared each of them to each other in a Digibuss. Furutech describes them on their site.
DRN
I use the Maestros here for the last5 years or so. Had the Furutech Rhodium models $180 each sold them
These were better to my liking. Depends on your  system.
Rogue CM Dark 2 SVS SB2000Pro Sonus Faber Sonetto 2  CA Emotion SE CMB Carbon Satisfy Arm Phoenix Falcon PS
Hanna ML Shelter 501 lll
Hagerman Trumpet mc3 Nos tubes
Belden 8402 Duelund 12ga SC
Yggdrasil+LIM CECTL5 Trans
Wiim ultra Qobuz
Surge x power
ejk
Don't know what type of outlet I have but I know it came from Fremer so hopefully it's good
S Clark
Several years ago at AC, member Big Red Machine built a multi outlet device with multiple parallel high end outlets and sent it out on tour.  They each clearly sounded different.  The Maestro was my favorite.
GDHAL
Quote from: S Clark on January 10, 2023, 06:53:01 AM
Hi S Clark. That reads like a really kewl idea! A question about that, if you don't mind. The multi-outlet device with parallel high-end outlets had to have been plugged into an outlet of some type. In your opinion is it possible (I imagine at least conceivable) that the outlet it was plugged into could somehow have influenced the characteristics of other outlets? This would be akin to plugging different amplifiers into the same preamplifier and then observing if any differences. No?
I've read nothing but good things about Maestro outlets.  :thumb: But suppose the multi-outlet device with parallel high-end outlets was itself plugged into a Maestro outlet. You get (read) my point.
Quote from: DRN on January 09, 2023, 06:26:49 PM
   Rhodium is a bitch to break in. Takes 500 hours to stop the hardness. Dave of PIAudio and I almost gave up after 300 hours. Very open big stage but Hi Fi sounding not musical IMHO.
Folsom
Rhodium isn't for me. It's thin and weird sounding.
I like what Dave does, polishing.
Quote from: Folsom on January 10, 2023, 01:23:05 PM
  Has its advantages in transparency and openness but not musical.
ejk
Weren't Hubbell outlets popular years back?
ejk
Folsom
Quote from: ejk on January 10, 2023, 07:32:24 PM
Still popular with me.
