Author Topic: Sound dampening on amp lid  (Read 5593 times)
Offline malloy
« on: October 14, 2023, 09:24:18 PM »
I've already applied dynamat to my Sony media player's top cover, with good results. Wanted to try something that won't likely melt on the amp's lid. It rattle and rings.
Looking at Audio Additives 3M or Soundcoat.
Any suggestions? Herbie's Dampening Sheet?
Thanks!
Paul
Re: Sound dampening on amp lid
« Reply #1 on: October 15, 2023, 07:34:28 AM »
Sorbothane is a very good visoelastomer for damping items.  It will adhere to surfaces.
Just a thought.
« Reply #2 on: October 15, 2023, 09:14:18 AM »
Thanks!
Paul
Let us how know how that turns out, Paul. My house has been rattling a bit breaking in my 12” subs. It can get quite annoying 🙄
Offline malloy
« Reply #3 on: October 15, 2023, 09:28:10 AM »
Just a thought.
Thanks, will check some out.  :thumb:
Offline malloy
« Reply #4 on: October 15, 2023, 09:34:30 AM »
Whoah! Maybe some sub isolators like a pad or feet? Don't know if that would reduce the sound quality and bass output, though.
« Reply #5 on: October 15, 2023, 12:30:11 PM »
Paul,
I was able to find the most two offending locations and fixed those. So that settled things down quite a bit. I’m nearly done with break in. Then adjusting /dialing them in will be interesting I’m sure.
« Reply #6 on: October 19, 2023, 02:40:17 PM »
Dynamat can withstand the heat in an engine bay, should be able to handle an amplifier ;)
Offline malloy
« Reply #7 on: October 19, 2023, 09:20:52 PM »
Good point! Been reading some opposing viewpoints, though. Some say too much can 'kill' the sound.
I last played around with different footers, spikes, decouplers, etc. years ago and this is the first time I'm putting anyting inside.
I guess this is another rabbit hole.  :lol:
« Reply #8 on: October 20, 2023, 09:43:05 AM »
You can look into that rabbit hole by taking a big, heavy book and set it on the top of the amp.  This will give you an idea of what damping will do.
