video on comparison of resistors
Started by Nick B, March 03, 2024, 10:02:56 AM
Last night, I was doing a search and found a prolific poster on Agon who appeared to be quite knowledgeable and a nice guy as well. He referenced a video that gave a detailed and informative description of the characteristics of a number of different resistors. Included was the AMRG which is used in my Hattor Big active/passive preamp. He mentioned a significant improvement after 20-50 hours of use and it sure appears he knows what he's talking about. I've noticed a significant improvement as well and it coincides with my hunch that the seller had put very few hours on the Hattor.
Here's the link:
https://youtu.be/EqikiOi4AAc?si=2CIO2Ef_MFCDf1ex
Spiritual Sound complete loom
Good video.  He pretty much said what I have found.
I don't have experience with the Audio Notes, but I've used the others, in addition to Riken.
The best platform to hear resistor differences is in high gain applications like guitar amps and pedals, IME.  These types of circuits show the beauty and ugliness of components quickly.
I like Takman carbon and metal films a lot.the AMRG resistors are exactly like he described. Kinda meh and then opening up nicely.  Smooth..............
Folsom
Seems accurate. The start with Dales.... I am more than fine using them all over.
#3
I remembered my webpage, copied the text, where resistor comparisons are made.
Hope this helps.
Sonic Comparisons of Resistors, Links to Capacitor Articles:
Below are reprints of two articles comparing different types of resistors, Bulk Foil, Melal Film, Wire Wound, Metal Glaze, Metal Oxide, and Carbon film. While not exhaustive, I think one can get a good general idea of how the different types compare, sonically. Although some metal film types are inferior sounding to carbon types, in general metal films are clearly superior. Since metal films are so abundant, the price has come down considerably. Carbons, on the other hand have gone up in price, since very few, if any, are manufactured in the USA. They are not extensively used because of the high fire risk. Now for the articles.
Piece De Resistance, By Martin Coloms:
"A selection of resistors was requested, and those we received were subject to test at two values, 100 ohms and 33k ohms. The 100 ohms were used as the main load resistor for a moving coil cartridge, with a preamp input impedance of 1k ohm. By careful gain calibration, the load effect was assessed in absolute terms, while the resistors were also assessed via a single-presentation method of judging overall asound quality. The 33k ohm types were assessed while used as the main termination for a CD player of low output impedances (100 ohms), the associated preamplifier input impedance being 100k ohms. Again, comparisons were made without a test resistor to assess the degree and type of sonic aberration introduced by the resistors under examination."
"Some earlier listening work has been done; for example, a fabricated metal-film array for a 2w value was compared with an equivalently rated wire-wound (Pot Pourri, Sept '86). In another small test, included in the previously published capacitor comparisons, a few resistors were auditioned as moving-coil cartridge loads. Here the Holco type was compared with carbon composition, carbon-film and low cost metal-film types. Holco won that contest (HFN/RR, Oct '85). In the present test the rarely-used carbon composition types were not included; previously tested examples were unpromising. Wire-wound, several metal-films, metal-glaze, and carbon-film types are represented here, together with the costly bulk-foil designs. Not all types in the survey were available in the 33k ohm value."
"...Compared with other projects, the listening work here was extremely difficult, and as such I would judge it rather less reliable. It is said that resistor sound quality is easier to judge if complete amplifiers are built largely with one type; comparisons are then made more easily as the effects are multiplied. But the scoring for resistor sound is an arbitrary one, and has no connection with that for amplifiers, CD players or cables. It is merely relative."
Interim comment
Whilst the sample is fairly limited, it was interesting that the carbon-film types sounded a little better than some of the metal-films. But Roedenstein's good reputation for an inexpensive metal-film (No. 11) seems well justified. We were fortunate to have the Vishay bulk-foils (No. 10), since these really proved our case, namely that resistors do affect sound quality. The Vishays were significantly nearer the original, helping to show the magnitude of the test loading effects, which were comparatively minor, and also revealing the audible errors' introduced by most of the other resistor types tested.
In general, resistors add a 'glazed' and 'hashy' noise in the treble which seemed to dilute stereo focus. Other effects included as impression of mildly bumpy or lumpy bass, with some forwardness in the midrange and a noticeable loss of depth, ambience and dymanic power. In the case of the latter, some of the resistors under test gave a blander and more lifelss effect to the reproduction.
Results:
1) MFRS, 0.5W, 1% metal-film, by Welwyn.
33k: 33.09, 33.03, 100 ohms: 100.28, 99.81
Sound 70%: thinner lighter sound, depth compression, lowered treble focus.
2) MFR4, 0.25w, 1% metal-film, by Welwyn.
33k: 33.01, 33.01, 100 ohms: 99.61, 100.1
Sound 72.5%: slight improvement in depth and tonal balance.
3) MRS16, 1% metal-film, by Mullard/Philips.
33k: 32.9, 33.04: 100 ohms: 100.05, 100.43
Sound: 75%: mixed reactions at 100 ohm, better banance and improved persepective at 33k.
4) MRS25, 0.6 W, 2% metal-film, from Mullard/Philips.
33k: 33.06, 33.03, 100 ohms: 99.28, 98.89
Sound 77%: a lively sound with better bass but a touch of 'brashness' in the treble.
5) BTF4, .25W, 5% carbon-film, by Dublier.
33k: 33.43, 33.15. 100 ohms: 99.28, 98.89
Sound 72.5%: fair balance, some blandness with a mildly lumpy bass.
6) SFR25, 0.33W, 5% metal-film.
33k: 33.43, 33.15: 100 ohms: 99.02, 99.15.
Sound 80%: a welcome improvement, more dynamic, better balanced, improved focus.
7) CFR50, 0.6W, 5% carbon-film by Neohm.
33k: 33.07, 32.67. 100 ohms: 99.31, 98.95
Suond 77.5%: a good impression of depth, despite some 'glaze' in the treble and slight bass boom.
8) NK3, 0.125W, 2% metal-film, by Corning.
33k: 32.99, 32.74. 100 ohm: 99.90, 100.1
Sound 71%: mild 'glaze' and diffusion in the treble, better depth heard at 100 ohm value.
9) CFR25, 0.25W, 5% carbon-film, by Neohm.
33k: 32.77, 32.95, 100 ohms N/A.
Sound 77%: quite good all-arounder.
10) VSRJ, 0.25W, 0.01% bulk-foil, by Vishay
36k: 36.02, 36.02, 100 ohms: 100.05, 100.06
Sound 94%: an unmistakeably large step nearer to no resistor at all. Clear, tonally balanced, fine depth, negligible aberration.
11) 0.25W, 2%, metal-film, by Roederstein
33k: 32.93, 32.81, 100 ohms: 99.55, 99.84
Sound 82%: strong dynamic sound with fairly good clarity, focus , and depth, but a touch of boom and a trace of 'glazed' treble brightness.
12) W21, 2.5W, 5% wire-wound vitreous, by Welwyn
33k, N/A, 100 ohms: 100.04, 100.07
Sound 86%: some dulling of air and a mild 'wirey' emphasis on string tone; good bass, slightly forward mid, but good clarity, dynamics and depth.
13) RS, 2.5W, 5% wirewound silicone cement coated, CGS
33k: N/A, 100 ohms: 98.7, 99.2
Sound 86%: similar to the above but slightly sweeter, with good instrumental separation. Mildly band limited, faint rolloff at the frequency extremes.
14) Econistor, 0.1%, precision wirewound, non-inductive, by Rhopoint.
33k: N/A: 100 ohms: 100.01, 100.005
Sound 86%: slightly soft bass, good focus, very slightly 'wirey' on strings; mild mid presence, good depth.
15) H8, 0.125W, 0.5% precision metal-film (Holco).
33k: N/A. 100 ohms: 100.31, 100.07
Sound 88%: a very fair copy- neutral, well balanced, clear and clean strings, good depth, slightly soft bass, very mildly defocused, accurate.
16) LR1, 0.25W, 1% metal-film, by Neohm
33k: N/A. 100 ohms: 100.04, 100.42
Sound 73%: some treble brittleness and grain, loss of depth and ambience: bass 'thumpy', loss of focus.
17) RGP0207, 0.5W, 1% metal- glaze, by Neohm.
33k: N/A. 100 ohms: 100.00, 100.12
Sound 76%: a touch forward and bright, but not too brittle or grainy. Fair bass and focus, some loss of depth and dynamics.
18) 'Commercial', 0.5W, 5% carbon-film, from Japan.
33k: N/A. 100 ohms: 98.49, 102.59
Sound 80%: some 'nasality' on violin, but clearer and less grainy than average. Quite good depth, fair bass and reasonable tonal balance.
19) N/A, 0.5W, 5% metal-oxide (obsolete), by Welwyn.
33k: N/A. 100 ohms: 100.10, 102.50
Sound 80%: quite neutral, fairly good depth, with some softening of detail; a touch bland and undynamic.
Hi-Fi News and Record Review, October 1985:
"For interest's sake, some subjective tests were performed on resistors during the capacitor auditioning. Only a few types were tried, more generic than specific, and only in one application, namely as the 100 ohm shunt loading function for an m-c cartridge, as reported on by Christopher Breunig a few months back (HFN/RR June, 1985). The test cartridge was an Empire van den Hul MC1000 and the preamp an SP-8."
"The judgments are arbitrary to some extent, based on the listeners' experience of sound quality 'improvement'. Even if the reader disagrees as to the true meaning of the observation - is it a change or an improvement? - the results do suggest that the resistors differ in their effect on the system's sound quality. Given the minute power and voltage levels involved in the test application, it is highly unlikely that thermal or voltage stress effects- which would result in the nominal resistance being modulated by the signal - are involved."
"We emerged from this brief series of tests feeling that while resistor differences were difficult to identify, significant differences were nevertheless present. The effects may well be diffferent in alternative circuit positions and at different power and voltage levels, but in this application, only the Holco proved capable of loading the cartridge without apparently degrading the sound quality of the SP-8 preamplifier to some extent. The other four resistors were felt to reduce the sound quality sufficiently to make the question of optimum resistive loading for the cartridge irrevelent. They were best omitted altogether."
R1 Make: Holco Score 91%
Type: 100 ohm metal film
Comments: Very small effect; tight precise stereo and good overall control.
R2 Make: RS Components Score 86%
Comments: Trace of 'muddle'; slight loss of space; a touch of treble grain, and a softer bass.
R3 Make: Roederstein Score 84%
Comments: Good bass sound, with pleasing depth but a slight grain and 'zzz' in the treble. A slightly 'muzzy' effect in the midrange.
R4 Make: Anonymous Score 70%
Type: 100 ohm carbon film, 1/4 watt
Comments: 'Zitty' defocused sound; 'louder' and mildly fatiguing; grainy treble.
R5 Make: RS Components Score 64%
Type: 100 ohm carbon film, 1/4watt
Comments: Defocused and grainy sound, with a loss of bass definition, stereo depth and focus.
Left out was the Caddock resistors. I performed a test and found the Caddock M-132 to be inferior to both the Vishay, Holco, and Roderstein. Sounded dull in comparison.
On Capacitor Dielectric Materials - A Chemist's View, by Karl A. Weber, Ph.D
Picking Capacitors, by Walter Jung and Richard Marsh
This paper is presented in the interests of the public.
SAS 11A Perceptual Perfect Tube Preamp
SAS 25 W Ref Triode 50 W UL
Quote from: steve on March 09, 2024, 10:43:30 PM
I remembered a webpage, copied the text, where resistor comparisons are made.
Hope this helps.
Interim comment
Results:
Thanks, Steve!
Hope this helps.
Interim comment
Results:
Great resource!
Years ago (30?) I got beat up because I commented upon TCR being extremely important in FR smoothness.  Ignorant people making unfounded comments.
One present case in point.  I recently built a multiple parallel DAC that is Redbook centric.  I have tons of data.  Duh.  The design uses passive I/R digital conversion.  There is no comparison in this application.  The nude Vishay resistors are as close to absolute transparency as can be expected.
Stupid expensive, but what isn't in this obsession?
Oh, yeah.  Stupid expensive?  ~ $12.00 each.  Stupid affordable for geeks.
#6
Thanks Dave. I just found this link comparing multiple resistors. I have no idea if the conclusions and rankings
are accurate but I have tried the Vishay bulk foil and found it amazingly good.
https://www.hificollective.co.uk/sites/default/files/hfc_stepped_series_resistor_review.pdf
#7
Since we are discussing resistors, it costs so much to order, typically $25 minimum order
plus expensive shipping.
I was wondering if I could purchase
two or three 47 ohm 1/2 watt metal film resistors, and
two or three 39 ohm metal film 1/2 watt metal film resistors from someone?
I am glad to pay for resistors and shipping.
cheers and thanks.
Quote from: steve on March 15, 2024, 09:17:19 AM
I'm excited to get my new/old NOS DAC broken in.  I'm presently using the naked foils in my much modified dB Audio Labs Tranquility SE and they are extremely smooth and transparent.  Changing from a random metal film with a TCR of 50ppm - 150ppm to one with a TCR of 2ppm is obvious in clarity.
TCR certainly isn't the overarching predictor of performance.  There is always Johnson and current noise, but a low TCR parameter is a very good indicator of overall technical performance.  Then the question is: does "it" sound good?  In the proper applications the naked foils are unmatched.
Quote from: P.I. on March 15, 2024, 11:05:44 AM
Yes, I totally agree with the assessment of the  naked foils. I use them plus Vishay bulk foil potentiomenters. Expensive but well worth the money imo.
I hope you are very satisfied with the sound after breakin of your NOS dac Dave.
I'm fortunate to have a Subratek Chardonnay tube preamp and a recent purchase of a Hattor Big with a New Class D opamp and the Amtrans AMRG resistors. After having the Chardonnay in for a few weeks, I put the Hattor back in tonight and am very much enjoying the additional detail and purity of tone.
I did a search on utube and happened to find this brief clip with an Indian audiophile visiting in Japan with the president of Amtrans.
https://youtu.be/irFHeIEfPhw?si=UQ0osLyeS4D3s8S2
