Looking for a used Modi 2 dac (obtained)
Started by steve, June 18, 2024, 07:54:49 PM
I am looking for a used Modi 2 dac to purchase. Please PM me.
Thanks.
Mimir Modified DAC
SAS 20 W Ref Triode 40 W UL
James Edward
Chord Qutest DAC
#2
Quote from: James Edward on June 21, 2024, 07:01:25 AM
PM sent
Thanks for the offer James but I needed the same model due to the parts I use.
I obtained one close by and all is well and bliss.
Thanks again for the offer James.
Mimir Modified DAC
#3
Received a generous gift from another, so I can compare the original to my upgraded dac.
Mimir Modified DAC
Quote from: steve on January 07, 2025, 04:19:10 PM
Let us know what you think, Steve. By the way, I really love my Holo Cyan2 dac. What an excellent dac and a great bargain for the money 🎶
Quote from: Nick B on January 07, 2025, 10:26:27 PM
I compared the original Modi 2 and my upgraded one and no contest.
Polypropylene capacitors in the analog power supply clearly elevate it to a
top notch position.
Are you thinking upgrade Cyan2 analog stage?
Mimir Modified DAC
Quote from: steve on March 12, 2025, 05:06:42 AM
top notch position.
Glad you were able to confirm that. The Cyan2 is a quality piece, very compact and very heavy and built like a tank. I would not want anyone to mess with it.
With a different piece like the Starkrimson Ultra amp, there's lots of room within the chassis. So having someone mod that would not be a problem for me.
#7
Hi Nick,
Interestingly, I found that my modified Modi 2 was not found by my
"new" windows 10 pc, but still works with my windows 7 pc.
Fortunately, my recently gotten modi 2 was found by windows 10, so I
exchanged the boards and power supply, and all is ok again. If I had not had the
backup Modi 2, all those caps for nothing.
I see others have had problems with windows 10 not seeing the Modi 2.
By the way, I had a chance to compare my upgraded Modi 2 and it was close
to one of the Denafrips. I will get back with the model, but I believe it was
in the several thousand dollar range.
Mimir Modified DAC
Quote from: steve on May 04, 2025, 10:01:36 PMHi Nick,
Steve,
I used Windows XP and 7 for a long time and both OS were stable and good to use. I have a friend who bought a Windows 8 laptop I believe and gave up figuring out how to use it. I'm content with Apple OS. I am presuming Windows 7 can continue to be used, but there's no longer support for it.
Glad you continue to get very good results with that Modi 2 👍
Quote from: Nick B on May 05, 2025, 05:52:43 PM
Steve,
I have a friend who really likes the Apple OS. It does sound wonderful.
Yes, going all polypropylene filter caps with DA of 0,02% in the analog
sections of any dac, and preamplifier will improve the performance of
said components to world class.
Another key is finding the correct value ufd, best materials and termination
technique of said capacitors.
Mimir Modified DAC
Quote from: steve on June 12, 2025, 07:02:45 AM
Steve,
Steve,
The Apple ecosystem has worked great for me since I started using it exclusively in about 2013. I've been able to call support hundreds of times with questions and they are available seven days a week.
You mentioned termination techniques on caps and I'm hoping you can elaborate a bit on that. Do you mean different solders, solderless or ...?
#11
Quote from: Nick B on June 12, 2025, 08:23:13 AM
Steve,
Steve,
Some info is directed for newbies to more easily understand my reply to Nick.
With that said, capacitors are usually round in nature. Two conductor plates with insulating
material is wound into a cylinder shape. One lead is to one conductor and the other lead
is connected to the other conductor.
Different ways to connect the lead wire to its respective foil.
1. A lead wire is simply connected to the edge of the foil, at only
one point on the foil.
Important: See fig. A and B. I am talking internally, NOT what you see when looking at
the outside as shown.
    A. When lead wire is connected to one point on the foil, say near the center
of the body's radius, and the other lead wire is connected to the opposite foil,
near the outside edge of the capacitor's body, the sound is usually fuller.
    B. When both leads are connected to their foils, near the center of the capacitor
body, the sound is almost always thinner, bright.
    C. When both leads are connected to their foils, near the outside edge of the
capacitor body, the sound is almost always thinner, bright.
    D. One can vary the distance between connection points adjust the brightness or
fullness of the sound. However, this is still not conducive to optimum accuracy.
2. A lead wire is placed across the edges of the foil. More contact than point 1.
See fig. C
3. A lead wire is centered and metallic spray is sprayed across a portion or all of the
edges of the respective foils. This minimizes the inductance created by rolling the foil.
See fig. D. The thickness and material(s) used will affect the accuracy.
Wish I could be a better artist, but no such fortune.
Mimir Modified DAC
Admin
Quote from: steve on June 13, 2025, 10:16:40 AM
Steve,
Steve,
See fig. C
Steve,
Steve,
See fig. C
Thanks, Steve. Quite interesting information and rather amazing that such slight changes can affect the sound just from an individual part and cumulatively together with other parts.
Quote from: Nick B on June 13, 2025, 09:11:15 PM
Steve,
Steve,
See fig. C
I had no idea when I started this venture in 1980 that I would find just how sensitive
the ear is. I deal with 1 part in 4 million, really incredible.
Those turns when when winding a capacitor quickly adds inductance, and the thickness of
the foil, the dimensions determine the dc resistance. Doesn't seem like much, but sure
makes a difference as you have found out over the years.
In college I learned that one needs to be able to reproduce 10 times less and above
a rectangular waveform's fundamental frequency to reproduce faithfully. Not a bad rule
of thumb, although 200khz is rather high.
Mimir Modified DAC
