Power Resistors
Started by steve, October 01, 2024, 08:06:49 PM
When it comes to designs, say in cathode biased outputs, bypassing the power resistors
with good bypass capacitors does not alleviate the sonic effects that the power resistors
often cause.
I have found the Mills MRA resistors to be sonically exceptional. With that said, there is also an
MRB version. There is a physical difference.
1. The MRB incorporates a steel end cap where as
2. the MRA uses a "copper" end cap.
3. Both use copper leads
I have not compared the two for sonic differences, but wish that all become aware of the physical
differences. Material differences normally cause sonic differences.
Hope this helps.
Mimir Modified DAC
SAS 20 W Ref Triode 40 W UL
Folsom
What are the negative effects you experienced with some?
I am not opposed to sandcast trials because the inductance might actually be useful in a tube circuit, especially if you have multiple tubes. I think they are no cap?
Funny, the MRA is made by Vishay and was the one I wanted to look up, but I thought Mills was a different company - it is only in the crossover/electronics world from old catalogs.
#2
Quote from: Folsom on October 07, 2024, 12:32:51 PM
Sorry for the delay Folsom, been ill and deer struck my car.
Sand resistors are inductive, steel lead wires and element materials used, each affecting the sonics in
a different way, and depending upon the placement in the circuit.
What I have noticed most is that Mills MRA give a relaxed, natural sound when used in wide
bandwidth circuit designs. However, using designs with limited bandwidth, such as 12AX7/12AT7
etc tubes, may give sensation of lacking highs. This is very general opinion.
By the way, Mills MRAs affect sonics differently than Dayton non inductive power resistors. I prefer the
Mills MRAs, just sounds more natural/accurate.
Mills was purchased by Vishay some years ago. Vishay seems to have a monopoly on resistors these
days.
Mimir Modified DAC
Hi Steve,
Just curious if you've ever tried the Amtrans AMRG resistors? I have them in my Hattor Big preamp which sounds terrific
Quote from: Nick B on November 28, 2024, 10:36:19 AM
Hi Steve,
Hi Nick,
No, I have not heard of them. But then I have not been in the parts scene that much for a
decade or so. I just checked and they are carbon film, which I do not recommend.
But that is me personally. Even between the Mills and Dayton non-inductive resistors (heavily
bypassed) I could discern a sonic difference in the output stage.
Cheers
Mimir Modified DAC
Quote from: steve on December 02, 2024, 02:39:15 PM
Hi Steve,
Hi Nick,
Cheers
I appreciate your thoughts, Steve. I don't know much about resistors other than the usual well regarded ones. These AMRG resistors in my Hattor preamp are the priciest upgrade and it is such a wonderful sounding preamp. I may soon try the new Hattor 6ns7 tube buffer as a result.
#6
Quote from: Nick B on December 03, 2024, 05:47:56 PM
Hi Steve,
Hi Nick,
Cheers
Good luck with the new preamplifier Nick. What would be interesting is to have 4 preamps, each
with the different resistor types to compare sonics. :)
cheers and all the best
Mimir Modified DAC
Quote from: steve on December 05, 2024, 06:11:34 PM
Hi Steve,
Hi Nick,
Cheers
An interesting experiment that would be, Steve, although a bit on the expensive side side! I will let you know if I get that Hattor tube buffer.
Quote from: Nick B on December 05, 2024, 07:20:42 PM
Hi Steve,
Hi Nick,
Cheers
Sounds good Nick.
Cheers
Mimir Modified DAC
Quote from: steve on December 21, 2024, 05:32:47 PM
Hi Steve,
Hi Nick,
Cheers
Sounds good Nick.
Cheers
Hi Steve,
Santa provided a very unexpected and early gift. So it is with 95% -/+ certainty that I'll be ordering that Hattor 6ns7 buffer. As to tubes, maybe the new Ray Reserve line.
Quote from: Nick B on December 22, 2024, 11:44:25 PM
Hi Steve,
Hi Nick,
Cheers
Sounds good Nick.
Cheers
Hi Steve,
Sounds interesting Nick. Can I look for an evaluation/review, either after breakin, or along the way?
Mimir Modified DAC
Quote from: steve on December 27, 2024, 12:37:56 PM
Hi Steve,
Hi Nick,
Cheers
Sounds good Nick.
Cheers
Hi Steve,
Yes, Steve. I am about to order the 6ns7 buffer. The Hattor Big solid state preamp is so outstanding that the new version tube buffer is certainly worth taking a chance on.
I guess owner/designer Arek Kallas is a low key guy and doesn't really promote his products. He did ask me to write a review on the Hattor Big and I did. I'm so glad to have owned the Supratek Chardonnay 6ns7 preamp and now the Hattor/Khozmo line.
Quote from: Nick B on December 27, 2024, 04:43:19 PM
Hi Steve,
Hi Nick,
Cheers
Sounds good Nick.
Cheers
Hi Steve,
No. 5 needs more input, more input.   :D
Mimir Modified DAC
Quote from: steve on December 30, 2024, 01:02:44 PM
Hi Steve,
Hi Nick,
Cheers
Sounds good Nick.
Cheers
Hi Steve,
Not clear what you meant. Can you restate?
Quote from: Nick B on December 31, 2024, 11:36:32 PM
Hi Steve,
Hi Nick,
Cheers
Sounds good Nick.
Cheers
Hi Steve,
No. 5 is a robot from the movie Short Circuit. No. 5 claims to be alive after an incident. No. 5 arrives at this
lady's house and reads every piece of literature and watches tv all night, including the three stooges.
He constantly says, need more input, more input. Really an entertaining and futuristic movie.
Just my weird sense of humor.
Mimir Modified DAC
