Main Menu
Open Baffle Sub
Started by ejk, March 15, 2025, 05:44:29 AM
James Edward
Quote from: ejk on March 18, 2025, 05:23:42 AM
Quote from: HAL on March 17, 2025, 07:37:07 PM
Nick,
Yes, the system and room is being DSP EQ'd with very good results.
I was reading that some owners can't get below 30hz. What to do. Has anyome tried sealed subs with the open baffle speakers. That is not using dsp, sorry for the qoute
I think my situation is similar to yours- I have the M3 Turbo S, and I use sealed Hsu subs (ULS-15Mk2). I run the Spatials full range, and have my sub crossover at 40 Hz.
They pretty much disappear at this setting.
Because the Spatials are so efficient, be prepared to run the sub volume at a higher setting than you might be used to in other situations.
Chord Qutest DAC
Well maybe time to consider a non OB Speaker that actually goes down to 20HZ. Even 24 HZ like the Qln Prestige 3 as an example.
