New Tung Sol 6550 Testing vs New Mullards
Started by steve, May 01, 2025, 04:45:51 PM
Gents,
I have a new finding, but this time it involves the newly
manufactured Tung Sol matched octet of 6550 output tubes (TS for Tung Sol)
I must have 800 hours on the current quad output tubes.
I checked the idle current of each, and against the brand new TS quad
output tubes (10 hours?) today using an old chassis. The 800 hr TS
measured quite similar on average to the boxed new
tubes. And all 8 tubes measure ~4% of each other.
With such similarity between tubes I can only conclude not
much cathode deterioration.
Yet the side getters on the 800 tubes are ~75% used up. And I
ran 6.3 fil voltage for 75% of the time used. Plate/Cathode Voltage
~430 volts. RK = 620 ohms. I recently set the fil voltage to 5.8 volts.
I am really impressed with the longevity..
Measured Idle Current:    Used
A Tube                             52.4 ma
B                                      50.00
C                                      51.8
D                                      50.4
                                     New Tubes
A Tube                             51.04 ma.
B                                      50.56
C                                      50.88
D                                      51.28
Mimir Modified DAC
SAS 20 W Ref Triode 40 W UL
Quote from: steve on May 01, 2025, 04:45:51 PMGents,
A Tube                            52.4 ma
B                                      50.00
C                                      51.8
D                                      50.4
                                    New Tubes
A Tube                            51.04 ma.
B                                      50.56
C                                      50.88
D                                      51.28
Thanks, Steve. Quite interesting. Any thoughts on why the cathode longevity? Materials...coatings on the metals... gasses within the glass? If I get a tube amp at some point, I would be more inclined to get current tubes rather than going the NOS route.
Quote from: Nick B on May 01, 2025, 08:47:52 PM
A Tube                            52.4 ma
B                                      50.00
C                                      51.8
D                                      50.4
                                    New Tubes
A Tube                            51.04 ma.
B                                      50.56
C                                      50.88
D                                      51.28
Good questions Nick. Since the side getters were being used up,
1. either residual gas or gas being produced over time from heat is removed.
(Wish all tubes had side getters as the top getter never seems to be heated
high enough to be that effective.)
2. A second possible reason is very high purity materials were used. Even
small impurities in the cathode sleeve or oxides could also poison the cathode.
3. Over heating the cathode oxides will increase evaporation. My lowering the
filament voltage to the JJ E88cc tubes dramatically increased the life.
4. Related to reason 3, the oxide thickness applied to the cathode sleeve could
be thinner, thus shorter life.
5. A mixture of oxides are often used. The ratio of the mixture may be different
than NOS due to cost or other factors.
I wish I could go more in depth but I do not have the expertise nor necessary equipment
to provide more information.
Hope this helps by listing possibilities.
Mimir Modified DAC
Quote from: steve on May 02, 2025, 08:08:39 AM
A Tube                            52.4 ma
B                                      50.00
C                                      51.8
D                                      50.4
                                    New Tubes
A Tube                            51.04 ma.
B                                      50.56
C                                      50.88
D                                      51.28
Thanks, Steve. That's quite interesting with enough technical information. There may be a limited revival in tubes with some companies like Western Electric, Apos Ray, JJ, EH etc. I realize that longevity of new tubes is an issue for some. I have not gotten into that as I've only had a tube preamp recently. Over 30 years ago I dabbled briefly with VAC Mono 90s and a Modjeski RM 9.
#4
Quote from: Nick B on May 02, 2025, 09:58:03 AM
A Tube                            52.4 ma
B                                      50.00
C                                      51.8
D                                      50.4
                                    New Tubes
A Tube                            51.04 ma.
B                                      50.56
C                                      50.88
D                                      51.28
Hi Nick,
A little bad news. The new Tung Sol tubes with the hours but still had new cathode
characteristics; one started arcing over, destroyed. Only had 425 volts plate to
cathode idling about 70 ma. Guess some others were right on other forums, about a year and the
TS start arcing. What a shame. They do sound really good though.
Mimir Modified DAC
Good to know. Thanks Steve.
#6
Quote from: rollo on June 20, 2025, 07:51:08 AMGood to know. Thanks Steve.
Your welcome Charles. I did pull the used tubes numerous times and lay on their side while hot.
Maybe a grid warped?
I have the new quad in and I won't be pulling them out, so we will see after some
hours.
Cheers
Mimir Modified DAC
bmr3hc
Hi Steve
Where did you purchased these TS 6550 tubes from?
Henry
Quote from: bmr3hc on July 05, 2025, 06:14:56 PMHi Steve
Henry
Hi Henry,
I actually received these tubes as a gift from an old friend some years ago.
He may have gotten them some 15 years ago +/-.
Any thoughts on if there may have been an upgrade of some sort since then?
I am also thinking of purchasing another brand to check out, but don't want
a brand that was actually made in China and rebranded.
Mimir Modified DAC
#9
I am always looking to test new tubes, but so many and the cost of all is
high.
However, I just received some used Mullard KT88s, and I think I love the
tube more than the new Tung Sols 6550s I have been using.
1. Years of use and the cathode is still strong with the M.
2. Years of use and the side getters have almost no activation. TS a different story.
3. The new Mullards are a little more refined, esp in the mid and up. Bass is deep
and quite taught.
Can't wait till I get a new quad to check out.
ps. I meant I auditioned reissued Mullard KT88s, not nos.
Mimir Modified DAC
Quote from: steve on July 14, 2025, 08:23:12 PMI am always looking to test new tubes, but so many and the cost of all is
high.
and quite taught.
Glad you're able to do more testing, Steve. I look forward to the next quad as well
#11
Quote from: Nick B on July 16, 2025, 11:46:06 AM
high.
and quite taught.
Nick, got the whole quad new Mullard KT88s in yesterday and immediately, NO Comparison
to the new Tung Sols. Not even close.
The new Mullard KT88s just blew away the new TS 6550s, in just about every respect.
Can't wait to get more hours on them, 10 hours on them.
Cleaner sounding, crisper/attacks, more natural bass, venue is much
more realistic, realism is in another class.
The JJs, SEDs, Sovteks, Chinese aren't even close in my setup.
The TS etc will be used for movies or back up, or something else.
The new Mullard KT88s are now the standard for me.
Cheers
Mimir Modified DAC
Quote from: steve on July 25, 2025, 11:52:32 AM
high.
and quite taught.
Cleaner sounding, cleaner, crisper/attacks, more natural bass, venue is much
Cheers
That's great news, Steve. I checked the prices and they seem quite reasonable as well, especially because of the level of performance you are describing 👍🎶
#13
Quote from: Nick B on July 25, 2025, 04:19:25 PM
high.
and quite taught.
Nick, got the whole quad new Mullard KT88s in yesterday and immediately, No Comparison
Cheers
My buddy sent me a pair of used and I thought they would improve the sound.
The TS were quite old, 15 years?, but new and I used them for a 1000 hours +/- and
the side getters were 75% degraded or more. But they still tested new.
My buddy told me that Mullards have been used for 6 years and the side getters are hardly
degraded.
Cleaner sounding, crisper/attacks, more natural bass, spaciousness, realism, live is in another class.
It is difficult to explain. The speakers have disappeared for 30 years, I have been into realism,
live sound for multiple decades as well, but the TS slightly full, masked the transparency, spaciousness.
The Mullard's got rid of that last bit of  masking and opened up the spaciousness,
One doesn't probably care or notice it until one hears the difference, the naturalness, still more
like live music.
Cheers
Mimir Modified DAC
#14
I just compared the new, reissued Mullard KT88s to my Winged C KT88s,
and I like the Mullards better.
The WC KT88s are softer sounding, which is probably better for many.
the M KT88s have a cleaner leading edge, midrange that is not as soft,
and taught bass compared to other tubes, but boy do they sound live.
The only caveat I have is, if one's audio system is already on the lean side due to
too small of coupling or decoupling capacitor(s), the Mullards might sound lean.
The Mullard is definitely my reference tube.
Cheers
Mimir Modified DAC
