Aluminum Blocks
Started by rollo, January 19, 2026, 11:47:01 AM
  If you want to channel the vibrations from your component to a shelf or plinth below check these out. Amazon 4x2x1. $27 for 6. Very affective.
Quote from: rollo on January 19, 2026, 11:47:01 AMIf you want to channel the vibrations from your component to a shelf or plinth below check these out. Amazon 4x2x1. $27 for 6. Very affective.
Amazon link pls or more info on the description.
toobluvr
#2
Very useful link.   Thank you!    :rofl:
TT2: OL Aurora/OL Silver Mk3A
 Not a computer guru here. Just go to Amazon and search Alum Blocks. Comes right up.
Quote from: rollo on January 20, 2026, 08:02:22 AMNot a computer guru here. Just go to Amazon and search Alum Blocks. Comes right up.
A search under aluminum blocks yielded a number of results. Here's one link
5 PCS 4 x 2 x 1 Inches Square Aluminum Flat Bars 6061 General Purpose Plate Aluminum Block Aluminum Bar for Milling Lathe Work, Machining, Cutting,
Industrial
 https://a.co/d/4N0Y3aH
There ya go. Alum drains/transfer vibration very well.
