why do some systems need higher volume settings to sound good
Started by Nick B, May 16, 2026, 11:28:06 PM
Quote from: P.I. on May 24, 2026, 08:10:04 PMI've had systems that were TFL at 10:00 and others at 3:00.  It's a function of speaker sensitivity, preamp gain and power amp input sensitivity.  Whatever.
It matters not where the volume control is set.  It is just the representation of the overall system sensitivity/gain/sensitivity equation.
I had a system with a passive "preamp" that sounded awesome at 3:00 and not so much at noon.  We need to feed our systems what they want.
Thanks, Dave. Passive sounds crappy with the Hattor. Either the 6 or 9dB setting on it are fine.
I have never looked specifically for high sensitivity speakers. Maybe one of these days I will. But the JMR is a great speaker and I have a good chunk of change invested in it.
As it's the best sound I've ever had, I have little to complain about 👍
Jack
Where do you have the gain control on the Elvis set?  Holger recommended to me to set it at 12 o'clock and raise or lower the gain setting on the preamp to compensate.  The actual number on the preamp display is really irrelevant as you're looking for the best sound with the lowest noise. What that 12 o'clock setting on the Elvis actually makes the input sensitivity I don't know but I took his advice and have it set there at least during breakin.
Vista Phono II Mk II
Jays Audio CDT3 Mk 3
Aric Audio Motherlode XL
Erhard Elvis Mk2
Aqua La Scala Mk3
Auralic Aries G2.2
Verity Arindal
(4) Rythmik F12SE
(2) Kinki Tai-Hang
Veritas & TWL PC's
Quote from: Jack on May 24, 2026, 09:30:50 PMNick
Jack,
I have always had the gain control at maximum. I thought that would  provide the best performance and lowest noise. My system is very low noise as is. But I will play with the game control starting at the 12 o'clock position and see what happens.
Jack
If at the maximum setting you don't hear any tube rush then you're OK but if so I would back it down and increase the Hattor's gain to it's maximum setting.
Erhard Elvis Mk2
Aqua La Scala Mk3
Auralic Aries G2.2
Verity Arindal
(4) Rythmik F12SE
(2) Kinki Tai-Hang
Veritas & TWL PC's
ejk
Quote from: ejk on May 24, 2026, 09:19:28 AM
Quote from: Jack on May 24, 2026, 08:04:01 AMFor now I'm running the Motherlode XL at full gain and the gain control on the Elvis at 50% so likely somewhere between 21-25db gain on the amp. I just got the Elvis yesterday so still experimenting on the correct balance on the two gain controls as my Verity Arindal's are 93db semsitivity. I was running the Motherlode at full gain on the 25s with the jumpers on the amps removed.
Seems pretty high on the Motherlode. Right now the jumper is removed on my Mono 25 and I have the super 6sn7 gain on 2.
I actually have egg on my face.I went to switch out amps and i'm  running the preamp the same way the gain is on the highest. Don't know why I thought it was on the second setting.
Jack
With the gain on the Elvis at 12:00 or halfway and the Motherlode at full gain normal listening level is at the low 30,s on the Motherlode dial. I suspect the halfway gain setting on the amp the builder recommended is pretty close to the jumpers off setting on the 25s. With the temperatures steadily rising here it won't be long before the tube amp goes on vacation for a bit.
Erhard Elvis Mk2
Aqua La Scala Mk3
Auralic Aries G2.2
Verity Arindal
(4) Rythmik F12SE
(2) Kinki Tai-Hang
Veritas & TWL PC's
I have the gain at 3:00 on the Elvis and there is still no noise. Have the Raytheon 6NS7 GT playing and it is more holographic and crisper in the treble and upper midrange.
Quote from: ejk on May 28, 2026, 06:04:36 AM
Huh? Thought audiophiles didn't make mistakes 🤭
That is how audiophiles learn, making mistakes. That is why we have Dealers to help put together a system that has a synergy. Money is NOT the answer to great sound. Knowing what goes with what is the key. Things like input impedance, gain matching, function matters. Cables matter however they will not fix an issue. Dry is dry, bright is bright, hard is hard. They may help but not eliminate the main issue.
ejk
Quote from: ejk on June 10, 2026, 03:53:53 AMNick has the Orchard been retired?
Just for a while, Evan. I am enjoying the tube rolling and tube sound. I still think the Starkrimson Ultra is a very good amp and especially for the price I got it for.
The Sylvania VT 231 is a great tube and I have another tube coming Friday from eBay. It's an RCA 6NS7GTB black plate side d getter (not sure what that all means...) The Sylvania will be tough to beat.
The RCA 6NS7GTB arrived today and is playing. Am waiting for the vocals to smooth out a bit and for the soundstage to expand.
Quote from: Nick B on May 16, 2026, 11:28:06 PMMy system requires I crank up the volume to sound the best. I am wondering if this is mostly a function of the speaker design and the driver materials used. Or do the components have more of an effect than the speakers?
Hi Nick,
I attached a graph of perception ability vs frequency. X axis is frequency and Y axis is
how many db it takes for the average person to perceive. If the system is a little lean, I would think it
would take higher spl to "fill out" the music, across the board.
Hope this helps Nick.
Mimir Modified DAC
SAS 20 W Ref Triode 40 W UL
Quote from: steve on June 16, 2026, 07:18:40 PM
Hi Nick,
Thanks, Steve. Certainly an interesting chart. I haven't measured SPL recently, but I guess my average listening level might be 80-85 dB. Will have to check again.
As an aside, that RCA 6NS7GTB is sounding very nice...
Quote from: Nick B on June 17, 2026, 01:16:04 PM
Hi Nick,
Hi Nick,
It is rather interesting and difficult if I may say as the recording may be thin, or full to begin with
depending upon the recording equipment, including mics replacement etc.
For individuals just entering the audio world, a little example of
science and audio perception. (I have not heard of audio perception being taught
in any college classrooms.)
For example, at 80 db spl, an average person can hear/perceive down to ~30hz,
and the midrange sounds louder than the bass.
As spl lessens (the volume reduces) the average person perceives the midrange even more
than the bass, so sounds leaner/thinner.  Inversely, when the volume is increased, the bass
increases vs the mids/highs.
What happens is that there is an spl recording level where the frequency response we
perceive is the flattest from bass through midrange and highs. It also depends upon the
mic placement, room acoustics etc. Some 50% of the musical quality is determined by the
recording process.
I hope this helps every one.
Mimir Modified DAC
