why do some systems need higher volume settings to sound good
Started by Nick B, May 16, 2026, 11:28:06 PM
My system requires I crank up the volume to sound the best. I am wondering if this is mostly a function of the speaker design and the driver materials used. Or do the components have more of an effect than the speakers?
ejk
Jack
Combination of preamp gain and amplifier input sensitivity.  Your Hattor has a low ouput gain of 0,3,or 6db and both of your amps have input sensitivities over 2 volts.
Vista Phono II Mk II
Jays Audio CDT3 Mk 3
Aric Audio Motherlode XL
Erhard Elvis Mk2
Aqua La Scala Mk3
Auralic Aries G2.2
Verity Arindal
(4) Rythmik F12SE
(2) Kinki Tai-Hang
Veritas & TWL PC's
Quote from: Jack on May 19, 2026, 10:25:31 AMCombination of preamp gain and amplifier input sensitivity.  Your Hattor has a low ouput gain of 0,3,or 6db and both of your amps have input sensitivities over 2 volts.
Jack,
Can speaker materials ever play a role? IOW, are certain materials a bit harder to drive?
It seems I have usually had systems that require me to crank up the volume, which I enjoy doing anyway.
But because of the excellent sound nowadays, I pay more attention to that type of thing.
Jack
No not really, it's the overall efficiency of the complete speaker system. Some materials like the Be tweeter on the Carerra can make you want to turn things down unless you design the rest of the system with it in mind.For example I could only enjoy mine with an all tube front end to dull it down.
Erhard Elvis Mk2
Aqua La Scala Mk3
Auralic Aries G2.2
Verity Arindal
(4) Rythmik F12SE
(2) Kinki Tai-Hang
Veritas & TWL PC's
Quote from: Jack on May 19, 2026, 10:01:25 PMNo not really, it's the overall efficiency of the complete speaker system. Some materials like the Be tweeter on the Carerra can make you want to turn things down unless you design the rest of the system with it in mind.For example I could only enjoy mine with an all tube front end to dull it down.
Thanks. That Be tweeter was tough to handle sometimes.  It's nice there's no need to have to turn down the Voce Grandes
Where is your volume control set at 10, 12, more ? Gain is the issue. What is the gain of your amp ? preamp ? Total gain matters. What is the sensitivity of your speakers and power of your amp ? Synergy of gain IMHO is one of the most important things.
Quote from: rollo on May 23, 2026, 08:26:14 AMWhere is your volume control set at 10, 12, more ? Gain is the issue. What is the gain of your amp ? preamp ? Total gain matters. What is the sensitivity of your speakers and power of your amp ? Synergy of gain IMHO is one of the most important things.
Charles,
Am using +9db on the Hattor preamp. I don't know the gain on the Erhard amp. Jack just got one and maybe he can chime in. My guess is 21 db. My speakers are 88.5 db as I recall. A terrific sounding system for a reasonable amount of money.
ejk
Quote from: Nick B on May 23, 2026, 11:52:05 PM
Charles,
I can't keep up with Jack :shock:
Jack
For now I'm running the Motherlode XL at full gain and the gain control on the Elvis at 50% so likely somewhere between 21-25db gain on the amp. I just got the Elvis yesterday so still experimenting on the correct balance on the two gain controls as my Verity Arindal's are 93db semsitivity. I was running the Motherlode at full gain on the 25s with the jumpers on the amps removed.
Erhard Elvis Mk2
Aqua La Scala Mk3
Auralic Aries G2.2
Verity Arindal
(4) Rythmik F12SE
(2) Kinki Tai-Hang
Veritas & TWL PC's
I'm talking gain of components. Combined gain. IMHO the gain of preamp and amp should not exceed 26db.
ejk
Quote from: Jack on May 24, 2026, 08:04:01 AMFor now I'm running the Motherlode XL at full gain and the gain control on the Elvis at 50% so likely somewhere between 21-25db gain on the amp. I just got the Elvis yesterday so still experimenting on the correct balance on the two gain controls as my Verity Arindal's are 93db semsitivity. I was running the Motherlode at full gain on the 25s with the jumpers on the amps removed.
Seems pretty high on the Motherlode. Right now the jumper is removed on my Mono 25 and I have the super 6sn7 gain on 2.
S Clark
Nick--  9 dB gain from the  preamp isn't low, but it certainly isn't high.  Add kinda moderate efficiency speakers and a moderate power amp...   it may simply be that your at the system's limit of comfort.
Quote from: S Clark on May 24, 2026, 11:54:16 AMNick--  9 dB gain from the  preamp isn't low, but it certainly isn't high.  Add kinda moderate efficiency speakers and a moderate power amp...   it may simply be that your at the system's limit of comfort.
Scott,
The 9dB setting is max and I have the volume control on the Erhard at max. I don't know what attenuator Holger uses on his amp, but I wouldn't want it affecting the output. I've never had speakers above 88.5 dB efficiency. As I said, the system sounds great. Just have not heard any system at lower volume reveal as much as when I have to crank mine up a bit.
I've had systems that were TFL at 10:00 and others at 3:00.  It's a function of speaker sensitivity, preamp gain and power amp input sensitivity.  Whatever.
It matters not where the volume control is set.  It is just the representation of the overall system sensitivity/gain/sensitivity equation.
I had a system with a passive "preamp" that sounded awesome at 3:00 and not so much at noon.  We need to feed our systems what they want.
